shakes when accelerate/reverse
Old 08-04-2011, 04:23 PM
tatitup8's Avatar
tatitup8
tatitup8 is offline
Default shakes when accelerate/reverse
problem.....
started my truck, put in reverse to back out of driveway, and when i pushed the pedal to give it some gas, the truck started to shake, like (in a front to back motion).... wtf??? does it in drive too.. too scared to drive it now.. and i have to take my girlfriend home and i have to go to practice. help!
EDIT: i also don't have all the power im supposed to..
Old 08-04-2011, 04:34 PM
tatitup8's Avatar
tatitup8
tatitup8 is offline
Delete
Old 08-04-2011, 04:59 PM
tatitup8's Avatar
tatitup8
tatitup8 is offline
Jus drove around block, when not accelerating oil pressure is fine, when accelerating the pressure goes up. ??
Old 08-04-2011, 05:25 PM
Brent Jones's Avatar
Brent Jones
Brent Jones is offline
Its normal for your oil pressure to go up when you accelerate.
Old 08-04-2011, 05:30 PM
tatitup8's Avatar
tatitup8
tatitup8 is offline
Drastically and drops when I let off the pedal?
Old 08-04-2011, 06:10 PM
tatitup8's Avatar
tatitup8
tatitup8 is offline
3 people said its prolly the transmission
Old 08-04-2011, 06:22 PM
aim4squirrels's Avatar
aim4squirrels
aim4squirrels is offline
How drastically do the RPM's rev when you push it?
A general rule of thumb is 10psi oil pressure for every 1000RPMs. That isn't an exact figure, so don't go quoting it as scripture, but the oil pump is driven by the camshaft, so the faster then engine goes, that faster the oil pump pushes oil. Are you traveling outside of the normal range of the oil pressure on your dash gauge? If it's in the normal range, don't go looking for a problem that isn't there.
Your transmission could be taking a dump, but you could have other issues like torque converter drain back, or a loose band that needs adjusting. I believe 1st and reverse are controlled by the same transmission band.
Old 08-05-2011, 12:01 PM
tatitup8's Avatar
tatitup8
tatitup8 is offline
ok, oil thing is fine.. i tuned truck to 93 octane the day before this started happening.. i had full tank of supreme (93) so i dont think this is the problem..
it also shakes when i change to 2nd gear or downshift from second. and shakes pretty bad when i push the pedal in to about idle speed
Old 08-05-2011, 12:42 PM
aim4squirrels
Did you happen to do any engine work?
If you did, Check the easy stuff like plug wires firmly on contacts and on the correct tower on the cap.
Old 08-05-2011, 01:44 PM
tatitup8's Avatar
tatitup8
tatitup8 is offline
I did the plenum about a month ago, changes plugs wires and tstat.
Quick Reply: shakes when accelerate/reverse
