Help spindle
Old 07-29-2011, 06:41 PM
DURANGO24's Avatar
DURANGO24
DURANGO24 is offline
Arrow Help spindle
I got a 98 durango and i need new spindles bc the previous owners stripped the brake caliper bolt holes on both sides and i put in the over sized bolts in but dont trust them
does anybody make new spindles other then the dealership
Old 07-30-2011, 02:04 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
You can get them from a number of sources like E-bay and many others. Just google it.
Old 07-30-2011, 04:27 PM
srch4me's Avatar
srch4me
srch4me is offline
just use a helicoil kit... thats what i had to do and it works perfectly
Old 07-30-2011, 04:40 PM
DURANGO24's Avatar
DURANGO24
Default spindle
yea but they r all used and thy can be the say way mine are already
Old 07-30-2011, 04:42 PM
DURANGO24's Avatar
DURANGO24
Default spindle
wht size helicoil kit u used and where did u get the bigger bolts to fit
Old 07-30-2011, 11:53 PM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
Part # BK6751539 = over sized caliper bolts from NAPA
Old 07-31-2011, 01:40 AM
srch4me's Avatar
srch4me
srch4me is offline
didnt need oversized bolts... the helicoil uses the same oem size bolts. you only drill enough to smooth it out and then tap it and put the coil in... umm the size on my98 was m9x1.25 metric
Old 07-31-2011, 03:02 PM
hydrashocker
I've seen many on there brand new not junkers. Just look around if you want new ones.
Regardless, the factory did a TSB on it and the helicoil kits are an approved alternative. However Indy's alternative is great as well:
Old 07-31-2011, 03:39 PM
srch4me's Avatar
srch4me
srch4me is offline
ive tried the oversized bolts and they work for a little while till the threads rust out even more... just my experience.. had to helicoil both sides of the rig... works perfectly... but if you have the money get new or used ones...
Old 07-31-2011, 05:26 PM
DURANGO24's Avatar
DURANGO24
ok thx
Quick Reply: Help spindle
