Old 08-13-2015, 05:52 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
Upper dash removal help
Old 07-19-2011, 11:33 PM
CSXfan's Avatar
CSXfan
CSXfan is offline
Default Upper dash removal help
Hey guys, I'm replacing the dash in my '99, but I'm having trouble removing the old one. Just a couple questions...
1. There are 4 screws still holding it in. 2 on the drivers side, and 2 on the passenger side. They're on the side of the dash and wedged right up against the cab. I can barely see them, much less get a wrench/screwdriver to them. How in the world am I supposed to get at them?
2. I was told that the steering colomn has to be dropped. If I just remove the two nuts on the underside of the column nearest the steering wheel, will it just drop down? Or is there more to it?
Old 07-20-2011, 07:27 AM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
no experience on the screws, but would a 90* screwdriver or bit in a socket help?
yes, remove the 2 screws and the column will drop down onto the seat.
Old 07-20-2011, 07:56 AM
XTREMEHUMPDOG's Avatar
XTREMEHUMPDOG
XTREMEHUMPDOG is offline
I used a ratchet wrench with a ton of extensions.
Remove the two bolts on the bottom of the steering column support bar. It will slide down and out a little and rest it on the seat.
You have the bolts against the window and then two bolts (one on each side) under the dash and near the kick panels. Two people would make it alot easier trust me..
Old 07-21-2011, 07:51 AM
CSXfan's Avatar
CSXfan
CSXfan is offline
Thanks guys. I think my problem is that I'm trying to separate the whole assembly from the metal frame. I guess that's not how you're supposed to do it. I'll give it another shot today.
I got my new dash from LMC truck yesterday, but when I opened the box, the dash was all scraped up like somebody had taken a rasp to it. I called LMC and they're sending me a new one so I can't complain too much, but I really wanted this done by the weekend.
Old 07-21-2011, 08:21 AM
XTREMEHUMPDOG
I learned the hard way. I had the usual dash cracks and thought that removing the bolts at the window would release the dask top as I was thinking about fiberglassing and painting it. Come to find out after I literally ripped the dash apart piece by piece that ther were screws holding it on that you normally wouldn't see unless you removed the dash from the firewall. Hope LMC makes it right and would love to see pics when done.
Old 07-21-2011, 10:17 AM
chadwall's Avatar
chadwall
chadwall is offline
So are you replacing the entire dash or just the top pad piece? I seen 2 options on their site for the pad, a $70 diffrence. What's the diff and which are you doing? Says they ain't crack for a short period if time...how long is that?
Thanks, I'm trying to decide best route to fix mine. I hate the carpet cover.
Old 07-21-2011, 10:22 AM
I think one is just a cover. Goes overtop of the current dash top, does not require removal of the dash. Other one would be a replacement part. Physically remove the dash, take off the old one, put on the new one, reinstall the dash. More work, but, in my opinion, better end result.
Old 07-21-2011, 10:23 AM
Gary-L's Avatar
Gary-L
Gary-L is offline
Please post pictures of the LMC dash BEFORE it's installed. Top and bottom if you please. I want to see what one of these looks like.
Old 07-21-2011, 10:38 AM
chadwall's Avatar
chadwall
chadwall is offline
Think the reinforcements they have would be good to use also? Is rather spend the extra and get the replacement rather than just glue one over.
Thanks!
Old 07-21-2011, 01:30 PM
krs7272's Avatar
krs7272
krs7272 is offline
IIRC there are 4-6 screws that enter from the backside of the dash towards the driver. As for the ones against the a-piller I use a super flat wrench. Got a set from sears for a few bucks.
Quick Reply: Upper dash removal help
