***help needed***
Old 07-18-2011, 07:25 AM
rebeccagrace's Avatar
rebeccagrace
rebeccagrace is offline
Default ***help needed***
I am desperate need of advice...I cross the Canadian border to work everyday from the US and my Nexus (commuter card) for crossing has fallen in behind the pull out cup holder of my van which I will now need to remove to retrieve the card. I have a 2011 Dodge Grand Caravan Mainstreet and am in a bind as I will need my ID by two when I am crossing to go home...
CAN ANYONE HELP ME???
Thank you in advance!
Old 07-18-2011, 07:39 AM
vpnavy's Avatar
vpnavy
vpnavy is offline
Until a Technician jumps in - I pulled this from your Owner's Manual. I'm not sure if this is the "cup holder" you are talking about. At any rate, maybe after removing it - you can find it...hope this helps...
iubongda123 (09-09-2019)
Old 07-18-2011, 08:43 AM
rebeccagrace
Default Stiill Need Help!
Okay, thank you for the info...it worked on getting the middle console out of the van...but... I think I gave wrong information. The van I have has six cup holders up front, four the the middle console between the captain chairs and two that pull out (like a drawer) from underneath the radio on the dash...
So does anyone know how to remove the cup holders that pull out from underneath the radio..?? I cannot find those in the manual...
Old 07-18-2011, 02:12 PM
hemi4spd's Avatar
hemi4spd
hemi4spd is offline
theres a little tab on the underside that keeps the tray from pulling all the way out.
look underneaath and you should see it, if not you should be able to "feel"it with your finger tips when the tray is fully extended out
push this little tab and pull it right out, thats it
is this what the cupholder your talking about looks like?
http://file.kelleybluebookimages.com...66_320x240.jpg
Old 07-18-2011, 02:21 PM
trophyslayer's Avatar
trophyslayer
trophyslayer is offline
not sure about yours,
but my 06 there is a push button in the middle top(in the back that you push down) then you pull the cup holders out
sorry about the pic quality, pics from my phone
Old 07-18-2011, 02:30 PM
vpnavy's Avatar
vpnavy
vpnavy is offline
Never mind.
Old 07-18-2011, 03:50 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Instrument Panel/CUPHOLDER, Instrument Panel/Removal
REMOVAL
1. Disconnect and isolate the negative battery cable.
2. Remove the fastener from the front of the floor console.
3. Pull the floor console forward to disengage the retaining tab from the floor bracket.
4. Remove the front floor console.
5. Remove the four plastic retainers that secure the instrument panel bin to the instrument panel.
6. Disconnect and remove the instrument panel bin cover .
7. Open the cupholder to the fully open position.
8. Remove the screw located under the cupholder.
9. Remove the the two screws located on the top edge of the cupholder.
10. Remove the cupholder for the instrument panel by pulling straight out.
Old 04-15-2012, 05:43 PM
5kids89's Avatar
5kids89
5kids89 is offline
Did you figure out how to remove the cup holder? I have the same problem in my 2010 Dodge Grand Caravan. A card slipped into the crack above the cup holder but below the radio and is now trapped in there somewhere. I need to get the cup holder out so I can retrieve it. Thanks for any help you can give.
Old 08-11-2013, 01:05 PM
naplesguitarist's Avatar
naplesguitarist
naplesguitarist is offline
I have the same problem but cant get the cup holder out. My wife's driver licensee is behind it. I removed the center console to give more room. Took off the rubber covers. I don't see or feel any switch to press on the remove the cup holder.
Old 08-11-2013, 01:06 PM
naplesguitarist
