terrible squeak/chirping need help!
I have a 2005 Dodge Ram 2500 4x4 and about 2 weeks ago it started making this squeak that would come and go. about 4 days ago it started and hasn't stopped since, at first I thought it was a belt but I revved it in park and neutral and nothing happened. The squeak then changed into more of a chirp and I noticed it was happening at idle speed in drive I would make the sound every three feet or so I moved, once I get on the gas the sound is at a constant very loud high pitch tone until the pitch gets to high and fades out, my friend told me to try and shake my drive shaft and see if the universals were bad so I checked the back drive shaft and it was solid as a rock but when I checked my front drive shaft it had some play when you tried to turn it so I thought that I had found the problem but my other friend told me that all Dodge front drive shafts have play in them so my question was #1 is that true? #2 can bad universals cause a chirp like that? and #3 is there any other problem that could cause a sound like that to happen? If you need any more info on what it sounds like or when the noise happens just ask. Can't wait to hear from someone thanks
