Fuel Pump Relay Bypass question
Old 07-08-2011, 10:55 AM
pixelpadre's Avatar
pixelpadre
pixelpadre is offline
Talking Fuel Pump Relay Bypass question
Omron G8h-UA-007001
I am trying to run a continuity check from PDC to fuel pump C121 harness. Does anyone know which blade on Fuel relay corresponds to wire running to fuel pump harness?
Thanks
Old 07-09-2011, 02:06 AM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
I hope this is what you are looking for.
TEST ACTION APPLICABILITY
4 Ignition Off
Disconnect the Fuel Pump Relay.
Note: Check connectors - Clean/repair as necessary.
Ignition on, engine not running.
Using a Voltmeter, measure the Fused Ignition Switch Output Circuit.
Is the voltage above 10.0 volts?
All
Yes ® Go To 5
No ® Repair the open Fused Ignition Switch Output Circuit.
Perform Powertrain Verification Test VER-2A.
5 Ignition Off
Using an Ohmmeter, measure across Terminals 85 and 86 of the Fuel Pump Relay for
resistance.
Is the resistance below 100.0 ohms?
All
Yes ® Go To 6
No ® Replace Fuel Pump Relay.
6 Ignition Off
Disconnect the Powertrain Control Module.
Using an Ohmmeter, measure the Fuel Pump Relay Control Circuit for resistance
from PCM to Relay.
Is the resistance below 5.0 ohms?
All
Yes ® Go To 7
No ® Repair the open Fuel Pump Relay Control Circuit.
7 Ignition Off
Using an Ohmmeter, measure the resistance of the Fuel Pump Relay Control Circuit
to ground.
All
Yes ® Repair the Fuel Pump Relay Control Circuit for a short to ground.
No ® Go To 8
8 Turn Ignition Off.
There are no potential causes remaining.
View repair options.
All
Repair
Replace the PCM.
178
DRIVEABILITY
P-1282 FUEL PUMP RELAY CONTROL CIRCUIT — Continued
Old 07-09-2011, 05:11 PM
pixelpadre's Avatar
pixelpadre
Thanks for the info. It will serve as a useful source of info for future readers. I will check it all out. Right now I have the filter off to check it. I have another post related to that.
Old 07-09-2011, 06:33 PM
pixelpadre's Avatar
pixelpadre
4 Ignition Off
Where would that terminal be? #85 86 etc
All
Yes ® Go To 5
5 Ignition Off
resistance.
ok thats clear.
All
Yes ® Go To 6
6 Ignition Off
from PCM to Relay.
OK what terminal are we talking about on the fuel pump relay?
All
Yes ® Go To 7
7 Ignition Off
to ground.
Looking for terminal location again.
All
No ® Go To 8
All
Repair
Replace the PCM.
178
DRIVEABILITY
Quick Reply: Fuel Pump Relay Bypass question
