2011 grand caravan power outlet issue
Old 07-07-2011, 08:44 PM
Dodge2008's Avatar
Dodge2008
Dodge2008 is offline
Default 2011 grand caravan power outlet issue
tonight my wife noticed that the 1 auxilliary power outlet (the left side) in the super console is not working. The one on the right however is. I tried using different items and we ended up with the same result. I even tried pushing it in harder, moving it/wiggling around, felt in there to see if anything was broken nothing.
Any ideas? I thought maybe fuse, but she has charged her cell phone in it several times without issue and it meets the power specs.
Is this common?
Thanks everyone
Old 07-07-2011, 11:37 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Do you have power with key in the on position?
Old 07-07-2011, 11:50 PM
Dodge2008's Avatar
Dodge2008
I have power to everything, including the tradition 2 prong outlet in back, the rear aux power outlet and the aux power outlet on the passenger side. The only one that seems to be dead both in the "on" or with the car running is the 1 aux power outlet. I didn't pull any fuses because I couldnt figure out which one it was and I couldn't see how my wife's cell charger (within) specs would blow it....im at a loss at 1,000 Ish miles
Old 07-08-2011, 12:53 AM
steak59's Avatar
steak59
steak59 is offline
Blown fuse, it is common. Sometimes those chargers have voltage spike when turn off. it could possible blow the fuse. Luckily, they r cheap, just a buy a pack from partstore, u'll need it in the future. Ur dealership will probably give u few fuses for free if u ask, since u just bought the car.
The cap of the fuse box should state "power outlet" on fuse label.
I know those fuse box picture and words are Microscopic , and the numbers and diagrams are as confusing as the periodic table.
so, just Check all the yellow 20amp fuses, if that's easier for u to do, there should be only like 6 or 7 yellow 20A.
I think all 3 power outlet fuse is more toward the front of the car for ur minvan.
Quick Reply: 2011 grand caravan power outlet issue
