P0545 - A/C Clutch, or EGT Sensor?
Old 07-07-2011, 07:51 PM
devinpitcher's Avatar
devinpitcher
devinpitcher is offline
Default P0545 - A/C Clutch, or EGT Sensor?
So doing some searching, I have found that everybody refers to P0545 being one of two things.
Exhaust Gas Temperature Sensor Circuit Low
or
A/C Clutch Relay Circuit Problem
Which is it?
A/C is working fine. Idle has always been a little rough since I got it, but code is new. Was told it smells like its running rich when driving, but at idle is smells fine. When I clear the code, it comes right back as soon as I turn on the ignition. Ideas? Maybe O2 sensor time? I'll bet they're originals with 200k on them.
Old 07-07-2011, 10:10 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
P0545 A/C Clutch Relay Circ
The reason they are messing it up is because that code is surrounded by exhaust CEL's. https://dodgeforum.com/forum/1st-gen...ine-light.html
As for your O2 sensors, make sure there is no brake fluid in or on the harnesses for them. However 200k miles, well you might want to replace them. I suggest Denso from www.rockauto.com because Denso makes the OEM ones.
Quick Reply: P0545 - A/C Clutch, or EGT Sensor?
