Power Seats Not Working 98' 4x4
Old 06-28-2011, 08:43 AM
Supertwins's Avatar
Supertwins
Supertwins is offline
Default Power Seats Not Working 98' 4x4
My daughter moved the driver seat forward and when I got in to drive the seat would not work, i checked the passenger seat and the same thing not working. I replaced the 50amp fuse under the hood and both seats are still not working. Is there a reset button somewhere, any help please?
Old 06-28-2011, 09:25 AM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
check the smaller fuses in the pdc under the hood, i believe one of them controls the seats (off the top of my head im not sure which one)
Old 06-28-2011, 12:22 PM
Supertwins's Avatar
Supertwins
I will be back home on Friday and will check it then...
Old 06-28-2011, 01:13 PM
shrpshtr325
THE ULTI-MOD
check fuse 4 (40A) in the PDC (under the hood)
Old 06-30-2011, 10:05 AM
Supertwins's Avatar
Supertwins
Roger that, I will do this tomorrow when I get home.
Thanks...
Old 07-03-2011, 08:23 AM
Supertwins's Avatar
Supertwins
I checked the fuses under the hood and all of them look good, I changed the 50amp fuse that is alloted for the seats but no luck...still stumped????
Old 07-04-2011, 10:47 AM
Old_School's Avatar
Old_School
Old_School is offline
I think your next step is to get a volt meter and start checking for voltage....
Old 07-07-2011, 02:40 PM
Supertwins's Avatar
Supertwins
Ok I pulled the fuse and turned the ignition key over and did not see voltage at the prongs, I took other fuses off and found voltage. What is the next step?
Old 07-07-2011, 02:52 PM
shrpshtr325
THE ULTI-MOD
so you dont have voltage at the fuse? then you need to figure out what happened to the wires that provide voltage to that fuse and either repair or replace it.
Old 07-07-2011, 09:46 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
Is there a relay for that?
Quick Reply: Power Seats Not Working 98' 4x4
