3rd Gen Durango 2011+ models
Check Engine Light (CEL) Codes
Old 06-22-2011, 03:47 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
Default Check Engine Light (CEL) Codes
These Codes and procedures provided by Master Tech
MODULE, Powertrain Control (PCM), NGC
Diagnosis and Testing
P000A-BANK 1 CAMSHAFT 1 POSITION SLOW RESPONSE (3.6L)
P000B-BANK 1 CAMSHAFT 2 POSITION SLOW RESPONSE (3.6L)
P000B-BANK 1 CAMSHAFT 2 POSITION SLOW RESPONSE (5.7L)
P000C-BANK 2 CAMSHAFT 1 POSITION SLOW RESPONSE (3.6L)
P000D-BANK 2 CAMSHAFT 2 POSITION SLOW RESPONSE
P0010-BANK 1 CAMSHAFT 1 POSITION ACTUATOR CIRCUIT OPEN
P0013-BANK 1 CAMSHAFT 2 POSITION ACTUATOR CIRCUIT OPEN
P0013-BANK 1 CAMSHAFT 2 POSITION ACTUATOR CIRCUIT OPEN (5.7L)
P0014-BANK 1 CAMSHAFT 2 POSITION TARGET PERFORMANCE (5.7L)
P0016-CRANKSHAFT/CAMSHAFT TIMING MISALIGNMENT
P0017-CRANKSHAFT/CAMSHAFT 1/2 TIMING MISALIGNMENT
P0018-CRANKSHAFT/CAMSHAFT 1/3 TIMING MISALIGNMENT
P0019-CRANKSHAFT/CAMSHAFT 1/4 TIMING MISALIGNMENT
P0031-O2 SENSOR 1/1 HEATER CIRCUIT LOW
P0032-O2 SENSOR 1/1 HEATER CIRCUIT HIGH
P0037-O2 SENSOR 1/2 HEATER CIRCUIT LOW
P0038-O2 SENSOR 1/2 HEATER CIRCUIT HIGH
P0051-O2 SENSOR 2/1 HEATER CIRCUIT LOW
P0052-O2 SENSOR 2/1 HEATER CIRCUIT HIGH
P0057-O2 SENSOR 2/2 HEATER CIRCUIT LOW
P0058-O2 SENSOR 2/2 HEATER CIRCUIT HIGH
P0071-AMBIENT AIR TEMPERATURE SENSOR PERFORMANCE
P0072-AMBIENT AIR TEMPERATURE SENSOR CIRCUIT LOW
P0073-AMBIENT AIR TEMPERATURE SENSOR CIRCUIT HIGH
P0107-MANIFOLD ABSOLUTE PRESSURE SENSOR CIRCUIT LOW
P0108-MANIFOLD ABSOLUTE PRESSURE SENSOR CIRCUIT HIGH
P0111-INTAKE AIR TEMPERATURE SENSOR RATIONALITY
P0112-INTAKE AIR TEMPERATURE SENSOR CIRCUIT LOW
P0113-INTAKE AIR TEMPERATURE SENSOR CIRCUIT HIGH
P0116-ENGINE COOLANT TEMPERATURE SENSOR CIRCUIT PERFORMANCE
P0117-ENGINE COOLANT TEMPERATURE SENSOR CIRCUIT LOW
P0118-ENGINE COOLANT TEMPERATURE SENSOR CIRCUIT HIGH
P0121-THROTTLE POSITION SENSOR 1 PERFORMANCE
P0122-THROTTLE POSITION SENSOR 1 CIRCUIT LOW
P0123-THROTTLE POSITION SENSOR 1 CIRCUIT HIGH
P0125-INSUFFICIENT COOLANT TEMP FOR CLOSED-LOOP FUEL CONTROL
P0128-THERMOSTAT RATIONALITY
P0129-BAROMETRIC PRESSURE OUT-OF-RANGE LOW
P0131-O2 SENSOR 1/1 CIRCUIT LOW
P0132-O2 SENSOR 1/1 CIRCUIT HIGH
P0133-O2 SENSOR 1/1 SLOW RESPONSE
P0135-O2 SENSOR 1/1 HEATER PERFORMANCE
P0137-O2 SENSOR 1/2 CIRCUIT LOW
P0138-O2 SENSOR 1/2 CIRCUIT HIGH
P0139-O2 SENSOR 1/2 SLOW RESPONSE
P0140-O2 SENSOR 1/2 NO ACTIVITY DETECTED
P0141-O2 SENSOR 1/2 HEATER PERFORMANCE
P0151-O2 SENSOR 2/1 CIRCUIT LOW
P0152-O2 SENSOR 2/1 CIRCUIT HIGH
P0153-O2 SENSOR 2/1 SLOW RESPONSE
P0155-O2 SENSOR 2/1 HEATER PERFORMANCE
P0157-O2 SENSOR 2/2 CIRCUIT LOW
P0158-O2 SENSOR 2/2 CIRCUIT HIGH
P0159-O2 SENSOR 2/2 SLOW RESPONSE
P0160-O2 SENSOR 2/2 NO ACTIVITY DETECTED
P0161-O2 SENSOR 2/2 HEATER PERFORMANCE
P0171-FUEL SYSTEM 1/1 LEAN
P0172-FUEL SYSTEM 1/1 RICH
P0174-FUEL SYSTEM 2/1 LEAN
P0175-FUEL SYSTEM 2/1 RICH
P0196-ENGINE OIL TEMPERATURE SENSOR CIRCUIT PERFORMANCE
P0197-ENGINE OIL TEMPERATURE SENSOR CIRCUIT LOW
P0198-ENGINE OIL TEMPERATURE SENSOR CIRCUIT HIGH
P0201-FUEL INJECTOR 1 CIRCUIT - 3.6L
P0201-FUEL INJECTOR 1 CIRCUIT - 5.7L
P0202-FUEL INJECTOR 2 CIRCUIT - 3.6L
P0202-FUEL INJECTOR 2 CIRCUIT - 5.7L
P0203-FUEL INJECTOR 3 CIRCUIT - 3.6L
P0203-FUEL INJECTOR 3 CIRCUIT - 5.7L
P0204-FUEL INJECTOR 4 CIRCUIT - 3.6L
P0204-FUEL INJECTOR 4 CIRCUIT - 5.7L
P0205-FUEL INJECTOR 5 CIRCUIT - 3.6L
P0205-FUEL INJECTOR 5 CIRCUIT - 5.7L
P0206-FUEL INJECTOR 6 CIRCUIT - 3.6L
P0206-FUEL INJECTOR 6 CIRCUIT - 5.7L
P0207-FUEL INJECTOR 7 CIRCUIT
P0208-FUEL INJECTOR 8 CIRCUIT
P0221-THROTTLE POSITION SENSOR 2 PERFORMANCE
P0222-THROTTLE POSITION SENSOR 2 CIRCUIT LOW
P0223-THROTTLE POSITION SENSOR 2 CIRCUIT HIGH
P0298-ENGINE OIL TEMPERATURE TOO HIGH
P0300-MULTIPLE CYLINDER MISFIRE
P0301-CYLINDER 1 MISFIRE
P0302-CYLINDER 2 MISFIRE
P0303-CYLINDER 3 MISFIRE
P0304-CYLINDER 4 MISFIRE
P0305-CYLINDER 5 MISFIRE
P0306-CYLINDER 6 MISFIRE
P0307-CYLINDER 7 MISFIRE
P0308-CYLINDER 8 MISFIRE
P0315-NO CRANK SENSOR LEARNED
P0325-KNOCK SENSOR 1 CIRCUIT
P0330-KNOCK SENSOR 2 CIRCUIT
P0335-CRANKSHAFT POSITION SENSOR CIRCUIT
P0336-CRANKSHAFT POSITION SENSOR PERFORMANCE
P0339-CRANKSHAFT POSITION SENSOR INTERMITTENT - 3.6L
P0340-CAMSHAFT POSITION SENSOR CIRCUIT - 5.7L
P0344-CAMSHAFT POSITION SENSOR INTERMITTENT - 5.7L
P0340-CAMSHAFT POSITION SENSOR CIRCUIT - 3.6L
P0344-CAMSHAFT POSITION SENSOR INTERMITTENT - 3.6L
P0365-CAMSHAFT POSITION SENSOR 1/2 CIRCUIT
P0369-CAMSHAFT POSITION SENSOR 1/2 INTERMITTENT
P0345-CAMSHAFT POSITION SENSOR 1/3 CIRCUIT
P0349-CAMSHAFT POSITION SENSOR 1/3 INTERMITTENT
P0390-CAMSHAFT POSITION SENSOR 1/4 CIRCUIT
P0394-CAMSHAFT POSITION SENSOR 1/4 INTERMITTENT
P0420-CATALYST EFFICIENCY (BANK 1)
P0430-CATALYST EFFICIENCY (BANK 2)
P0440-GENERAL EVAP SYSTEM FAILURE
P0441-EVAP PURGE SYSTEM PERFORMANCE
P0443-EVAP PURGE SOLENOID CIRCUIT
P0452-EVAP PRESSURE SWITCH STUCK CLOSED
P0455-EVAP PURGE SYSTEM LARGE LEAK
P0456-EVAP PURGE SYSTEM SMALL LEAK
P0457-LOOSE FUEL CAP
P0461-FUEL LEVEL SENSOR 1 PERFORMANCE
P0462-FUEL LEVEL SENSOR 1 CIRCUIT LOW
P0463-FUEL LEVEL SENSOR 1 CIRCUIT HIGH
P0480-COOLING FAN 1 CONTROL CIRCUIT
P0481-COOLING FAN 2 CONTROL CIRCUIT
P0501-VEHICLE SPEED SENSOR 1 PERFORMANCE
P0503-VEHICLE SPEED SENSOR 1 ERRATIC
P0506-IDLE SPEED PERFORMANCE LOWER THAN EXCEPTED
P0507-IDLE SPEED PERFORMANCE HIGHER THAN EXCEPTED
P050B-COLD START IGNITION TIMING PERFORMANCE
P050D-COLD START ROUGH IDLE
P0513-INVALID SKIM KEY
P0520-ENGINE OIL PRESSURE SENSOR CIRCUIT
P0521-ENGINE OIL PRESSURE SENSOR PERFORMANCE
P0522-OIL PRESSURE TOO LOW
P0523-ENGINE OIL PRESSURE SENSOR CIRCUIT HIGH
P0524-ENGINE OIL PRESSURE TOO LOW
P0532-A/C PRESSURE SENSOR CIRCUIT LOW
P0533-A/C PRESSURE SENSOR CIRCUIT HIGH
P0562-BATTERY VOLTAGE LOW
P0563-BATTERY VOLTAGE HIGH
P0571-BRAKE SWITCH 1 PERFORMANCE
P0572-BRAKE SWITCH 1 STUCK ON
P0573-BRAKE SWITCH 1 STUCK OFF
P0579-SPEED CONTROL SWITCH 1 PERFORMANCE
P0580-SPEED CONTROL SWITCH 1 CIRCUIT LOW
P0581-SPEED CONTROL SWITCH 1 CIRCUIT HIGH
P0585-SPEED CONTROL SWITCH 1/2 CORRELATION
P0591-SPEED CONTROL SWITCH 2 PERFORMANCE
P0592-SPEED CONTROL SWITCH 2 CIRCUIT LOW
P0593-SPEED CONTROL SWITCH 2 CIRCUIT HIGH
P0600-SERIAL COMMUNICATION LINK
P0601-INTERNAL MEMORY CHECKSUM INVALID
P0606-INTERNAL ECM PROCESSOR
P060B-ETC A/D GROUND PERFORMANCE
P060D-ETC LEVEL 2 APP PERFORMANCE
P060E-ETC LEVEL 2 TPS PERFORMANCE
P060F-ETC LEVEL 2 ECT PERFORMANCE
P061A-ETC LEVEL 2 TORQUE PERFORMANCE
P061C-ETC LEVEL 2 RPM PERFORMANCE
P0622-GENERATOR FIELD CONTROL CIRCUIT
P0627-FUEL PUMP RELAY CIRCUIT
P062C-ETC LEVEL 2 MPH PERFORMANCE
P0630-VIN NOT PROGRAMMED IN PCM
P0632-ODOMETER NOT PROGRAMMED IN PCM
P0633-SKIM SECRET KEY NOT STORED IN PCM
P063A-GENERATOR VOLTAGE SENSE CIRCUIT
P0642-SENSOR REFERENCE VOLTAGE 1 CIRCUIT LOW
P0643-PRIMARY 5-VOLT SUPPLY CIRCUIT HIGH
P0645-A/C CLUTCH RELAY CIRCUIT
P0652-SENSOR REFERENCE VOLTAGE 2 CIRCUIT LOW
P0653-SENSOR REFERENCE VOLTAGE 2 CIRCUIT HIGH
P0685-AUTO SHUTDOWN RELAY CONTROL CIRCUIT
P0688-AUTO SHUTDOWN RELAY SENSE CIRCUIT LOW
P06DA-DUAL STAGE OIL PUMP CIRCUIT
P06DD-DUAL STAGE OIL PUMP STUCK LOW
P06DE-DUAL STAGE OIL PUMP STUCK HIGH
P0700-TRANSMISSION CONTROL SYSTEM (MIL REQUEST)
P0703-BRAKE SWITCH 2 PERFORMANCE
P0850-PARK/NEUTRAL SWITCH PERFORMANCE
P1115-GENERAL TEMPERATURE RATIONALITY
P1128-CLOSED LOOP FUELING NOT ACHIEVED - BANK 1
P1129-CLOSED LOOP FUELING NOT ACHIEVED - BANK 2
P113D-O2 SENSOR 1/1 SLOW RESPONSE (HIGH FREQUENCY)
P113E-O2 SENSOR 2/1 SLOW RESPONSE (HIGH FREQUENCY)
P1239-ENGINE OIL TEMPERATURE TOO LOW
P1411-CYLINDER 1 REACTIVATION CONTROL PERFORMANCE
P1414-CYLINDER 4 REACTIVATION CONTROL PERFORMANCE
P1416-CYLINDER 6 REACTIVATION CONTROL PERFORMANCE
P1417-CYLINDER 7 REACTIVATION CONTROL PERFORMANCE
P1521-INCORRECT ENGINE OIL TYPE
P1524-OIL PRESSURE OUT OF RANGE - CAMSHAFT ADVANCE/RETARD DISABLED
P1572-BRAKE PEDAL STUCK ON
P1573-BRAKE PEDAL STUCK OFF
P1593-SPEED CONTROL SWITCH 1/2 STUCK
P1607-PCM INTERNAL SHUTDOWN TIMER RATIONALITY TOO SLOW
P1618-SENSOR REFERENCE VOLTAGE 1 CIRCUIT ERRATIC
P1628-SENSOR REFERENCE VOLTAGE 2 CIRCUIT ERRATIC
P1696-EEPROM MEMORY WRITE DENIED/INVALID
P1697-EMR (SRI) MILEAGE NOT STORED
P2066-FUEL LEVEL SENSOR 2 PERFORMANCE
P2067-FUEL LEVEL SENSOR 2 CIRCUIT LOW
P2068-FUEL LEVEL SENSOR 2 CIRCUIT HIGH
P2072-ELECTRONIC THROTTLE CONTROL SYSTEM - ICE BLOCKAGE
P2096-DOWNSTREAM FUEL TRIM SYSTEM 1 LEAN
P2097-DOWNSTREAM FUEL TRIM SYSTEM 1 RICH
P2098-DOWNSTREAM FUEL TRIM SYSTEM 2 LEAN
P2099-DOWNSTREAM FUEL TRIM SYSTEM 2 RICH
P2100-ELECTRONIC THROTTLE CONTROL MOTOR CIRCUIT
P2101-ELECTRONIC THROTTLE CONTROL MOTOR PERFORMANCE
P2107-ELECTRONIC THROTTLE CONTROL MODULE PROCESSOR
P2110-ELECTRONIC THROTTLE CONTROL - FORCED LIMITED RPM
P2111-ELECTRONIC THROTTLE CONTROL - UNABLE TO CLOSE
P2112-ELECTRONIC THROTTLE CONTROL - UNABLE TO OPEN
P2115-ACCELERATOR PEDAL POSITION SENSOR 1 MINIMUM STOP PERFORMANCE
P2116-ACCELERATOR PEDAL POSITION SENSOR 2 MINIMUM STOP PERFORMANCE
P2118-ELECTRONIC THROTTLE CONTROL MOTOR CIRCUIT
P2122-ACCELERATOR PEDAL POSITION SENSOR 1 CIRCUIT LOW
P2123-ACCELERATOR PEDAL POSITION SENSOR 1 CIRCUIT HIGH
P2127-ACCELERATOR PEDAL POSITION SENSOR 2 CIRCUIT LOW
P2128-ACCELERATOR PEDAL POSITION SENSOR 2 CIRCUIT HIGH
P2135-THROTTLE POSITION SENSOR 1/2 CORRELATION
P2138-ACCELERATOR PEDAL POSITION SENSOR 1/2 CORRELATION
P2161-VEHICLE SPEED SENSOR 2 ERRATIC
P2166-ACCELERATOR PEDAL POSITION SENSOR 1 MAXIMUM STOP PERFORMANCE
P2167-ACCELERATOR PEDAL POSITION SENSOR 2 MAXIMUM STOP PERFORMANCE
P2172-HIGH AIRFLOW/VACUUM LEAK DETECTED (INSTANTANEOUS ACCUMULATION)
P2173-HIGH AIRFLOW/VACUUM LEAK DETECTED (SLOW ACCUMULATION)
P2174-LOW AIRFLOW/RESTRICTION DETECTED (INSTANTANEOUS ACCUMULATION)
P2175-LOW AIRFLOW/RESTRICTION DETECTED (SLOW ACCUMULATION)
P2181-COOLING SYSTEM PERFORMANCE
P219A-AIR-FUEL RATIO CYLINDER IMBALANCE BANK 1
P219B-AIR-FUEL RATIO CYLINDER IMBALANCE BANK 2
P2245-O2 SENSOR 1/1, 2/1 REFERENCE VOLTAGE CIRCUIT LOW
P2246-O2 SENSOR 1/1, 2/1 REFERENCE VOLTAGE CIRCUIT HIGH
P2271-O2 SENSOR 1/2 SIGNAL STUCK RICH
P2273-O2 SENSOR 2/2 SIGNAL STUCK RICH
P2299-BRAKE PEDAL POSITION/ACCELERATOR PEDAL POSITION INCOMPATIBLE
P258A- ELECTRIC VACUUM PUMP CIRCUIT
P258D-ELECTRIC VACUUM PUMP PERFORMANCE
P2302-IGNITION COIL 1 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION
P2305-IGNITION COIL 2 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION
P2308-IGNITION COIL 3 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION
P2311-IGNITION COIL 4 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION
P2314-IGNITION COIL 5 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION
P2317-IGNITION COIL 6 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION
P2320-IGNITION COIL 7 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION
P2323-IGNITION COIL 8 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION
P2503-CHARGING SYSTEM OUTPUT LOW
P2504-CHARGING SYSTEM OUTPUT HIGH
P2610-PCM INTERNAL SHUTDOWN TIMER RATIONALITY TOO FAST
P3400-MDS RATIONALITY BANK 1
P3401-MDS SOLENOID 1 CIRCUIT
P3402-CYLINDER 1 DEACTIVATION CONTROL PERFORMANCE
P3425-MDS SOLENOID 4 CIRCUIT
P3426-CYLINDER 4 DEACTIVATION CONTROL PERFORMANCE
P3441-MDS SOLENOID 6 CIRCUIT
P3442-CYLINDER 6 DEACTIVATION CONTROL PERFORMANCE
P3449-MDS SOLENOID 7 CIRCUIT
P3450-CYLINDER 7 DEACTIVATION CONTROL PERFORMANCE
P3497-MDS RATIONALITY BANK 2
U0001-CAN C BUS
U0002-CAN C BUS OFF PERFORMANCE
U0100-LOST COMMUNICATION WITH THE ECM/PCM
U0101-LOST COMMUNICATION WITH TCM
U0103-LOST COMMUNICATION WITH ELECTRIC GEAR SHIFT MODULE
U0114-LOST COMMUNICATION WITH FINAL DRIVE CONTROL MODULE (FDCM) (ASBS)
U0121-LOST COMMUNICATION WITH ABS
U0141-LOST COMMUNICATION WITH IPM (FCM/TIPM)
U110A-LOST COMMUNICATION WITH SCM (SAS)
U110C-LOST FUEL LEVEL MESSAGE
U110E-LOST AMBIENT TEMPERATURE MESSAGE
U110F-LOST FUEL VOLUME MESSAGE
U1113-LOST A/C PRESSURE MESSAGE
U1120-LOST WHEEL DISTANCE MESSAGE
U1403-IMPLAUSIBLE FUEL LEVEL SIGNAL RECEIVED
U1411-IMPLAUSIBLE FUEL VOLUME SIGNAL RECEIVED
U1412-IMPLAUSIBLE VEHICLE SPEED SIGNAL RECEIVED
U1417-IMPLAUSIBLE LEFT WHEEL DISTANCE SIGNAL RECEIVED
U1418-IMPLAUSIBLE RIGHT WHEEL DISTANCE SIGNAL RECEIVED
MODULE, Transmission Control (TCM)
P0219-ENGINE OVERSPEED
P0602-CONTROL MODULE PROGRAMMING ERROR/NOT PROGRAMMED
P0604-INTERNAL CONTROL MODULE RAM
P0605-INTERNAL CONTROL MODULE ROM
P0613-INTERNAL TRANSMISSION PROCESSOR
P0614-ECM/TCM INCOMPATIBLE
P0643-SENSOR REFERENCE VOLTAGE 1 CIRCUIT HIGH
P0657-SOLENOID SUPPLY VOLTAGE CIRCUIT
P0710-TRANSMISSION TEMPERATURE SENSOR CIRCUIT
P0712-TRANSMISSION TEMPERATURE SENSOR LOW
P0714-TRANSMISSION TEMPERATURE SENSOR INTERMITTENT
P0717-INPUT SPEED SENSOR 1 CIRCUIT NO SIGNAL
P0730-INCORRECT GEAR RATIO
P0731-GEAR RATIO ERROR IN 1ST
P0732-GEAR RATIO ERROR IN 2ND
P0733-GEAR RATIO ERROR IN 3RD
P0734-GEAR RATIO ERROR IN 4TH
P0735-GEAR RATIO ERROR IN 5TH
P0741-TORQUE CONVERTER CLUTCH CIRCUIT PERFORMANCE
P0742-TORQUE CONVERTER CLUTCH STUCK ON
P0743-TCC SOLENOID CIRCUIT
P0748-MODULATOR PRESSURE SOLENOID CIRCUIT
P0752-1-2/4-5 SOLENOID
P0753-1-2/4-5 SOLENOID CIRCUIT
P0757-2-3 SOLENOID
P0758-2-3 SOLENOID CIRCUIT
P0762-3-4 SOLENOID
P0763-3-4 SOLENOID CIRCUIT
P0778-SHIFT PRESSURE SOLENOID CIRCUIT
P1629-TCM INTERNAL - SOLENOID SUPPLY/ WATCHDOG
P1631-TCM INTERNAL- PROCESSOR CLOCK PERFORMANCE
P1632-TCM INTERNAL - TEST INTERNAL WATCHDOG PERFORMANCE
P1633-TCM INTERNAL - TEST EXTERNAL WATCHDOG PERFORMANCE
P1634-TCM INTERNAL- INTERNAL WATCHDOG PERFORMANCE
P1636-TCM INTERNAL- EXTERNAL WATCHDOG PERFORMANCE
P1637-TCM INTERNAL-EEPROM PERFORMANCE
P1638-TCM INTERNAL-CAN 1 RAM PERFORMANCE
P1639-TCM INTERNAL-CAN 2 RAM PERFORMANCE
P1644-INCORRECT VARIANT/CONFIGURATION
P1704-INPUT SPEED SENSOR 1 OVERSPEED
P1705-INPUT SPEED SENSOR 2 OVERSPEED
P1731-INCORRECT GEAR ENGAGED
P2638-TORQUE MANAGEMENT FEEDBACK SIGNAL PERFORMANCE
P2767-INPUT SPEED SENSOR 2 CIRCUIT NO SIGNAL
P2783-TORQUE CONVERTER TEMPERATURE TOO HIGH
P2784-INPUT SPEED SENSOR 1/2 CORRELATION
U0100-LOST COMMUNICATION WITH ECM/PCM
U0121-LOST COMMUNICATION WITH ANTI-LOCK BRAKE MODULE
U0155-LOST COMMUNICATION WITH CLUSTER/CCN
U0164-LOST COMMUNICATION WITH HVAC CONTROL MODULE
U0401-IMPLAUSIBLE DATA RECEIVED FROM ECM/PCM
U0404-IMPLAUSIBLE DATA RECEIVED FROM ESM
U0414-IMPLAUSIBLE DATA RECEIVED FROM FDCM
U0415-IMPLAUSIBLE DATA RECEIVED FROM ABS
U0423-IMPLAUSIBLE DATA RECEIVED FROM CLUSTER/CCN
U0424-IMPLAUSIBLE DATA RECEIVED FROM HVAC CONTROL MODULE
U0431-IMPLAUSIBLE DATA FROM FCM
U110B-LOST ENGINE COOLANT MESSAGE
U1118-LOST ENGINE MESSAGE
U1119-LOST FCM MESSAGE
U1400-IMPLAUSIBLE TPS SIGNAL RECEIVED
U1401-IMPLAUSIBLE ENGINE SPEED SIGNAL RECEIVED
U1402-IMPLAUSIBLE ENGINE TEMPERATURE SIGNAL RECEIVED
U1404-IMPLAUSIBLE STATIC ENGINE TORQUE SIGNAL RECEIVED
U1405-IMPLAUSIBLE MINIMUM ENGINE TORQUE SIGNAL RECEIVED
U1406-IMPLAUSIBLE MAXIMUM ENGINE TORQUE SIGNAL RECEIVED
U1407-IMPLAUSIBLE ENGINE TORQUE REQUEST SIGNAL RECEIVED
U1408-IMPLAUSIBLE BRAKE SIGNAL RECEIVED
U1409-IMPLAUSIBLE LEFT FRONT WHEEL SPEED SIGNAL RECEIVED
U140A-IMPLAUSIBLE RIGHT FRONT WHEEL SPEED SIGNAL RECEIVED
U140B-IMPLAUSIBLE LEFT REAR WHEEL SPEED SIGNAL RECEIVED
U140C-IMPLAUSIBLE RIGHT REAR WHEEL SPEED SIGNAL RECEIVED
U140D-IMPLAUSIBLE WHEEL SPEED SIGNALS RECEIVED
U140F-IMPLAUSIBLE ENGINE VARIANT DATA
U1410-IMPLAUSIBLE/MISSING FCM VARIANT DATA
U1505-IMPLAUSIBLE MESSAGE DATA LENGTH RECEIVED FROM FDCM
U1507-IMPLAUSIBLE ENGINE TEMPERATURE MESSAGE DATA LENGTH RECEIVED
U1508-IMPLAUSIBLE MESSAGE DATA LENGTH RECEIVED FROM ESM
U1509-IMPLAUSIBLE ENGINE VARIANT MESSAGE DATA LENGTH RECEIVED
U150A-IMPLAUSIBLE FCM VARIANT MESSAGE DATA LENGTH RECEIVED
Quick Reply: Check Engine Light (CEL) Codes
