transfer case maintenance
Old 06-19-2011, 11:37 PM
srch4me's Avatar
srch4me
srch4me is offline
Default transfer case maintenance
so after my durango gets fixed from the wreck id like to overhaul the transfer case. like basic stuff. change the fluid and such. i need to know what to do and such. any suggestions on stuff to do while im doin that... should i change the fluid in the front differencial as well at the same time? any suggestions would be greatly appreciated...
Old 06-19-2011, 11:50 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
only real maintance on the t-case is fluid change, ATF +4 only
front and rear differentials should be changed with the appropriate weight of gear oil (check your manual) and friciton modifier in the rear if you have LSD
Old 06-20-2011, 12:26 AM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
Don't use ATF+4 in a 1998, stocker or equivalent replacement fluids only. 2000 is the transition year based on build date; some yes, some no. Same for the Powersteering unless adding all new equipment.
IndyD
Old 06-20-2011, 01:15 AM
srch4me's Avatar
srch4me
srch4me is offline
Indy, what should i use in a 98 for the transfercase? i know the tranny takes atf+4
Old 06-20-2011, 01:23 AM
IndyDurango
No ATF+4 in the 98 actually. ATF+4 for "everything" is internet rumor gone amuck. One can't just rely on what you read on the interwebs.
Directly from the FSM:
"Mopar ATF Plus 3, Type 7176 automatic transmission fluid is the recommended fluid for Chrysler automatic transmissions.
Dexron II fluid IS NOT recommended. Clutch chatter can result from the use of improper fluid."
+4 has different properties. In most old, high mileage applications like a '98 would be, just switching to +4 now results in the seals leaking. Usually all of them. Also, the mechanic will always need to know it is +4 becasue the wear poperties are different too (color, smell, etc usually used to diagnose "bad" fluid which are no longer applicable with ATF+4.)
IndyDurango
Old 06-20-2011, 09:24 AM
shrpshtr325
THE ULTI-MOD
i thought ATF +3 was no longer produced and that ATF +3 trucks should switch to +4 . . .
Old 06-20-2011, 11:12 AM
IndyDurango
Not produced from Chrysler, yes. All shops have equilv aftermarket +3 and will for decades.
As for "should switch"... def not. Well, not unless you want to adhere to Chrysler's nudge and end up buying a new vehicle in the long run.
Cause and Effect.
IndyD
Old 06-20-2011, 12:09 PM
shrpshtr325
THE ULTI-MOD
i didnt know that,
thanks for the info indy,
Old 06-20-2011, 02:15 PM
srch4me's Avatar
srch4me
srch4me is offline
as far as i knew atf+4 was a replacement for what was normally used because the normal fluid wasn't being manufactured anymore. i haven't seen atf+3 anywhere
Old 06-20-2011, 04:14 PM
Old_School's Avatar
Old_School
Old_School is offline
The Noob at the local Advance Auto Parts tried to tell me that Dodge recommends GEAR OIL in the transfer case! Guess i should have told him to a little closer.....
So you say that us '98ers should be using ATF+3? Where do they sell it anymore?? i have not seen it... im curious cause i plan to do a full fluid change sometime before fall..
Quick Reply: transfer case maintenance
