Hughes plenum plate or just new gaskets?
My truck has over 217k on it, and I plan on only getting 1 more year (possibly 2) out of it. I am starting to think about just saving the money and going with the Dorman Gasket replacement kit and upgrading to a 180-degree thermostat, instead of putting in the new plate. This decision is purely based on saving some coin as I am trying to buy a house right now, and I don't plan on having this truck for 5+ more years.
Give me your thoughts.
there is a guy on ebay selling a laser cut 1/4 plate for around $45, I just got mine in the mail from him...I have never seen the hughes one but this one looks top quality, and you will already be buying the gaskets anyway......in ebay punch in plenum plate or belly pan in the search tab...
The Plenum issue is caused by the plate and housing being made of 2 different metals. Over time, the 2 metals expand and contract at different rates, and eventually the gasket pops and you get the plenum issue.
The Huges pan will completely eliminate the plenum issue, as its made of a different metal that wont mess up the gasket.
That bieng said, if your not planning on having the truck for a long while, just do the gasket. New gasket will last a few years at least. The kit is more of a perminant fix.
The theory I generally believe to be true is that the tapped holes for the pan bolts were not drilled deep enough into the manifold and the pan bolts bottom out, not keeping the correct torque on the gasket. The hughes plate is 1/4" instead of the 1/16" steel pan, extending the bolt holes. I suspect that a few washers could just as easily solve the problem.
Spend $50 now on the kit, save $1000 later?
Jeff
just a fwiw- the cat is out of the bag on the plenum issue on these rigs.. most folks are going to ask that question.. some may even show up with a pen magnet to check for themselves.. even if they don't know, you can volunteer the job was done, and it was done right.. you'll get your worth out of the fix (no matter if you do the hughes or the other plate) fix.. just my thoughts..
