help!! I'm confused, what's wrong with my truck?
Old 06-10-2011, 06:07 PM
cowgirljenn's Avatar
cowgirljenn
cowgirljenn is offline
Unhappy help!! I'm confused, what's wrong with my truck?
i had replaced the alternator in my truck and the serpentine belt.... as soon as i started right after i got the belt on it it squeals bad and can smell burning rubber.. the belt is really tight and as soon as we start the truck i notice the tensioner will move a little bit... does anyone have any suggestions as to what is wrong with it this time??? PLEASE HELP I WANT TO DRIVE MY TRUCK
Attached Thumbnails help!! I'm confused, what's wrong with my truck?-photo-0056-640x480-635x425-635x425-.jpg
Old 06-10-2011, 06:20 PM
drewactual's Avatar
drewactual
drewactual is offline
are you certain you have it routed correctly? are you sure you have the right grooved belt?
you may need to start it BRIEFLY with the hood up and someone watching... just long enough to inspect each pulley and make sure they're rolling..
when what is happening to you happens, it's been my experience I routed teh belt wrong, or one of the pulleys is frozen..
Old 06-10-2011, 06:21 PM
dodgeram07's Avatar
dodgeram07
dodgeram07 is offline
is the alternator spings free lee? also are the other?
Old 06-10-2011, 06:27 PM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
Since this is a tech question, moved it to the main section. Should get more help that way.
Old 06-10-2011, 08:35 PM
97tn4x4's Avatar
97tn4x4
97tn4x4 is offline
The tensioner will move some, that's ok. I'm with everyone else, check the routing of the belt. Pull it back off and check each pulley too while you're at it.
Old 06-11-2011, 01:31 AM
Sheriff420's Avatar
Sheriff420
Sheriff420 is offline
Double check the part number for the belt or match it to the old one to make sure it's the right belt.
Quick Reply: help!! I'm confused, what's wrong with my truck?
