Air switches from vent to defrost when engine under load
Old 06-08-2011, 04:13 PM
1969usmc1988's Avatar
1969usmc1988
1969usmc1988 is offline
Default Air switches from vent to defrost when engine under load
Several years ago my 1996 1500 starting switching the air circulation from the main vents to the defrost whenever I put a load on the engine by accelerating. It doesn't matter if the A/C is on or not, Recirc or fresh. I have NO idea what could be causing this. I have reset the computer but that didn't help. Any ideas
John
Old 06-08-2011, 05:43 PM
Ramzy's Avatar
Ramzy
Ramzy is offline
Here is the info for "crazy vents" or "wacky vents". Do a search and you will find a boat load of threads.
It's a common problem.
https://dodgeforum.com/forum/2nd-gen...help-guys.html
https://dodgeforum.com/forum/2nd-gen...ild-vents.html
Old 06-08-2011, 10:02 PM
Stain96's Avatar
Stain96
Stain96 is offline
There is a vacuum line issue most likely... I had the same problem with my 1996; my mechanic told me it was one of the vacuum lines he replaced it, and it fixed my problem... If that is your problem then it is an easy and inexpensive fix. I would get that checked out before spending any big bucks...
Old 06-09-2011, 06:43 AM
neilsrpcustoms's Avatar
neilsrpcustoms
neilsrpcustoms is offline
It generally is going to be the line with the little white and black check valve in it. Sometimes the check valve itself just goes bad and doesn't hold constant vaccum to the dash feed.
Old 03-02-2013, 06:58 AM
1969usmc1988
Default Thanks
the crazy vent advice worked. No more issues. Thanks again
Old 03-02-2013, 09:40 AM
jkeaton is offline
Our work here is done then.
Quick Reply: Air switches from vent to defrost when engine under load
