symptoms of a bad torque converter
Old 06-02-2011, 08:56 AM
meanwhitemopar's Avatar
meanwhitemopar
meanwhitemopar is offline
Default symptoms of a bad torque converter
Ok so I got a hint to check my torque converter..
It makes sence, cause it doesn't shift right, then it lost 5th( which is just 4th with thw tc locked up)
Anyone hve any input on what else to look at.
Keep in mind, the tranny had water, then flushed with the wrong fluid...
Old 06-02-2011, 09:03 AM
97tn4x4's Avatar
97tn4x4
97tn4x4 is offline
Does it shift ok in all the other gears?
Old 06-02-2011, 09:46 AM
meanwhitemopar
It didn't shift very well at all in any gear before it just quit moving... I can put it ib gear and it shutters a little and barely moves
Old 06-02-2011, 10:10 AM
HeyYou is online now
Received 3,164 Likes on 2,918 Posts
How much water did you take on, and how long was it in there?
Old 06-02-2011, 02:08 PM
meanwhitemopar
I don't know how much water. Just enough to turn to milk shake. but it was there for almost 4 days.
Quick Reply: symptoms of a bad torque converter
