Which cyl. is #8 on 4.7l??
Old 05-28-2011, 02:22 PM
rollerbones's Avatar
rollerbones
rollerbones is offline
Default Which cyl. is #8 on 4.7l??
I have a 2000 4.7 in my Durango and I am getting a P0208 code (fuel injector). Which cylinder is #8 so I can check and replace injector?
Thanks
Old 05-28-2011, 02:52 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
I will move this to the 1st Generation DURANGO sub-forum.
Old 05-28-2011, 03:00 PM
rollerbones
From what I can find online it is the passenger side of engine next to firewall? Sound correct?
Old 05-28-2011, 06:45 PM
WhiteWidow00's Avatar
WhiteWidow00
WhiteWidow00 is offline
Yes, the driver side front-most is cylinder number one and the passenger side back-most is cylinder number 8. Here's a little diagram that will help you out...
Old 05-29-2011, 02:41 AM
MAGIC84's Avatar
MAGIC84
MAGIC84 is offline
on the 4.7 you will eventually know which one is the #8 when you go to remove/replace the spark plug...It is the one on the passengers side, nearest the firewall probably the most difficult to get at...recommend a universal and socket extension on your spark plug socket 5/8ths I believe.
Old 05-29-2011, 10:16 PM
rollerbones
I replaced the injector tonight and when I drove it around it feels like it is missing..... No check engine light came back on... yet... but now it have that "miss" feeling. Could I have possible cracked one of the vacuum hoses or just a possible connect loosened up? I will check tomorrow when there is light out again.
Old 05-30-2011, 11:15 AM
WhiteWidow00
If it is missing, it is missing and will throw a MIL. If it feels like it is missing, start by going through the motions of checking the vacuum lines and make sure your air filter isn't dirty or clogged. Also, it wouldn't hurt to use some SeaFoam to run through the system to clean out any deposits in the combustion chamber and injectors. Just get a can of SeaFoam from Wal-Mart or AutoZone or somewhere and use 1/3 of the can sucked up through the brake booster vacuum line and dump the rest in the gas tank.
Old 05-30-2011, 03:00 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
4.7L ENGINE
DESCRIPTION SPECIFICATION
GENERAL SPECIFICATIONS
Engine Type 90° SOHC V-8 16-Valve
Displacement 4.7 Liters / 4701cc
(287 Cubic Inches)
Bore 93.0 mm (3.66 in.)
Stroke 86.5 mm (3.40 in.)
Compression Ratio 9.0:1
Horsepower 235 BHP @ 4800 RPM
Torque 295 LB-FT @ 3200 RPM
Lead Cylinder #1 Left Bank
Firing Order 1-8-4-3-6-5-7-2
Number 1 is the driver side and 2 thru 8 are the passenger side.
Old 05-30-2011, 05:06 PM
rollerbones
no code is being thrown yet, but I can feel a difference like one of the injectors are not spraying.... (by firewall) I have checked all and the ohm is 12.5-13 on that side. I have also put a bulb on each connector and it is flashing when running. but still no code...
would a code throw if its clogged? The new one I got was a re manufactured injector but measures fine.
Old 05-30-2011, 05:22 PM
WhiteWidow00
It will not throw a code simply because it's clogged per say, but will throw a code if it notices a misfire was detected whether it be a constant miss or an intermittent miss.
Quick Reply: Which cyl. is #8 on 4.7l??
