battery terminal broken
Old 05-27-2011, 06:05 PM
trucker007's Avatar
trucker007
trucker007 is offline
Unhappy battery terminal broken
I need some help with my 07 Ram 1500 with HEMI. Had to remove the negative battery connection today, and managed to break the clamp. can this clamp be replaced with any generic type or does have to be Dealer specific? (my dealer wants 80$, includes wires)
Thanks for any help
Old 05-27-2011, 06:36 PM
Matt99's Avatar
Matt99
Matt99 is offline
they sell clamps at almost any auto parts house
Old 05-27-2011, 10:41 PM
bigdaddyII's Avatar
bigdaddyII
bigdaddyII is offline
I would replace a $3 wally world clamp once a year before I gave the dealer (or anyone) $80 for a battery clamp and cable.
Old 05-28-2011, 01:40 PM
Geezir's Avatar
Geezir
Geezir is offline
Problem with these trucks (and most if not all new vehicles for that matter) is the battery clamps are not replaceable anymore.
However you SHOULD have enough slack in the cable that you can cut off the broken clamp and put a generic one on.
Old 05-28-2011, 03:21 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
they make crimp type, solder and screw type clamps. the easiest IMO are the screw type, you just loosen the screw, slide the cable in (with about 1/2" stripped) and tighten the screw...
Old 06-01-2011, 04:25 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
use some good electric grease also to help prevent corrosion
Quick Reply: battery terminal broken
