33s on 2wd Ram?
Old 05-26-2011, 07:49 AM
Z.rawk95's Avatar
Z.rawk95
Z.rawk95 is offline
Default 33s on 2wd Ram?
Can I fit 285/70 17s on a 2wd ram w/o a lift if I get the right backspacing on whatever rims I get? If not what about 285/65 17s? I have only seen a few brands with this size, though. I tried a search, but couldn't find any straight answers on anything but 4x4s.
Old 05-26-2011, 09:04 AM
redheadhunter21's Avatar
redheadhunter21
redheadhunter21 is offline
It will rub most likely, certain brands of tire might not though(while driving on road)......be real easy to pick up a spacer and then not have to worry
A 1.5" daystar spacer is about $50 shipped
Never seen a 285/65/17 but it might fit.
Old 05-26-2011, 10:19 AM
TwistedCage's Avatar
TwistedCage
TwistedCage is offline
he might mean 285/70/16 but saying 17. before i got my 2001 i had a 96 1500 long bed club cab which i had 285/ cant remember if it was 70 or 75/16 on it with no lift 2wd only rubed at full lock
Old 05-26-2011, 10:47 AM
dodge dude94's Avatar
dodge dude94
dodge dude94 is offline
Banned Goober Smoocher
I saw a 2nd gen Ram at work this past weekend that had 285's on it. Looked great. It had Eagle Alloys that were deeper set than stock, so they stuck out. I noticed the driver's side fender liner had a hole cut it in, so they apparently rubbed.
Old 05-26-2011, 02:58 PM
Z.rawk95's Avatar
Z.rawk95
Z.rawk95 is offline
actually, the only ones I saw were yokohama geolanders in 285/65 17 (31.6 in tall and 11.6 wide), but I plan on getting some 17x8 cragar d-windows, so what backspacing should I get to cram them under?
Old 05-26-2011, 04:19 PM
redheadhunter21
From 4.25 to 5
Old 05-27-2011, 09:45 AM
Z.rawk95's Avatar
Z.rawk95
Z.rawk95 is offline
the 4.25 would give a deeper look to the wheel right? or is it the other way around?
Old 05-27-2011, 10:56 AM
More backspacing tucks the wheels further into the fenders. (and gives a higher likelihood of rubbing on the control arms. at least, on the 4wd guys....)
Old 05-27-2011, 01:51 PM
redheadhunter21
Yes your right, the less the backspacing the deeper the wheel will look
Old 05-27-2011, 02:52 PM
Z.rawk95's Avatar
Z.rawk95
Z.rawk95 is offline
redheadhunter21, what backspacing do your soft 8s have
