Turn Signal Relay
Old 05-26-2011, 12:17 AM
dizyspellz's Avatar
dizyspellz
dizyspellz is offline
Default Turn Signal Relay
Hey, i am new to this forum and had a quick question for all the dodge experts out there!
Where would i find the turn signal relay in a 2004 ram 1500 SLT 5.7L?
Old 05-26-2011, 06:52 AM
MikeHTally's Avatar
MikeHTally
MikeHTally is offline
Welcome aboard! Short answer: the cover of the power panel (under the hood) has the relay markings. If you're looking for the flasher, it's integrated into the instrument panel.
Old 05-26-2011, 09:14 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Welcome to the site.
While you are asking and searching, click on the link in my signature to download the Service Manual for your truck which has all that info and more in it
Old 05-26-2011, 08:05 PM
dizyspellz's Avatar
dizyspellz
thanx for the info!
so i take that if i want to have led switch back turn signal lights i will have to add resistors as i am unable to change the relay????
Old 05-27-2011, 03:09 AM
abarmby's Avatar
abarmby
abarmby is offline
Originally Posted by dizyspellz
thanx for the info!
The simple answer is yes.
You will have to tap into a turn circuit, wire into and add resistors, accordingly.
Al.
Old 05-27-2011, 04:57 PM
dizyspellz's Avatar
dizyspellz
would that void the factory warranty??
Old 01-09-2023, 11:43 PM
TRAVIESO59's Avatar
TRAVIESO59
TRAVIESO59 is offline
So the turn signal flasher is where?
Old 01-09-2023, 11:44 PM
TRAVIESO59's Avatar
TRAVIESO59
so is there a flasher for the turn signal?
Old 01-10-2023, 09:58 AM
What are you driving?
Old 04-11-2023, 04:33 PM
watcher67's Avatar
watcher67
watcher67 is offline
Wanting to upgrade headlights & turn signals to LED in an '03 Dakota. Can't find a flasher relay (hyper flash). Front light bulbs are a p.i.t.a. to change. There IS a listing for a "flasher relay" in parts book..
Quick Reply: Turn Signal Relay
