Fuel injectors makin noise.
Old 05-16-2011, 01:07 PM
hendrixx324's Avatar
hendrixx324
hendrixx324 is offline
Default Fuel injectors makin noise.
I no fuel injectors make noise but this morning when i fired up my truck i hurd tapping noises and at first i was pissed because i thiought my valves were tapping. after messin around with a screw driver to pinpoint the noise I found out my fuel injectors were makin the noise. they got pretty loud and i didnt notice it yesterday so my queston is do you think they are going bad? or is it makin the noise because it needs to give it more fuel.
Old 05-16-2011, 01:21 PM
donkeypunch's Avatar
donkeypunch
donkeypunch is offline
King Jackass
I seriously doubt you are hearing the injector making noise. But, if you feel that you need to verify the rule-out, then remove an injector and test it with jumper wires. Remember, an injector moves two ways...open and close. I think (based on your recent work) that you are hearing something in the valve train or rotating assembly. Can you take video of this noise and post it, say...youtube?
Old 05-16-2011, 02:23 PM
hendrixx324
my phone doesnt take a loud enough vid but when i put the screw driver tip on the valve cover it was very quiet.. then when i put it on the fuel rail its alot louder. and its 2 sounds one right after the other.
Old 05-17-2011, 02:40 AM
donkeypunch
King Jackass
Ok, have you isolated it to one injector?
Old 05-17-2011, 12:23 PM
hendrixx324
not yet? would i damage anything if i uplug one injector at a time?
Old 05-17-2011, 01:32 PM
wingman_214's Avatar
wingman_214
wingman_214 is offline
It wont hurt anything to unplug one injector at at time. As you unplug each injector the engine should run like crap. When you get to the bad one it should have the least effect.
Old 05-17-2011, 02:22 PM
hendrixx324
ok thank you ill go do that when it strops raining
Quick Reply: Fuel injectors makin noise.
