2006 Dakota Rear Drum Removal
Old 05-11-2011, 03:00 PM
mgham797's Avatar
mgham797
mgham797 is offline
Default 2006 Dakota Rear Drum Removal
I own a 2006 Dakota club cab, v6. I am having terrible problems with the brakes. The entire truck seems to shudder when I apply the brakes. I have changed the Front Rotors, Front brake pads, and also had Rear Drums Replaced. The shop did not replace the rear shoes, and I feel this may be the problem. I have been told I need special tool to pull the rear drums off. Can anyone help? Do I need anything special ??
Thanks,
Old 05-11-2011, 03:10 PM
dakota_raven's Avatar
dakota_raven
dakota_raven is offline
Thanks,
A hammer!!!
I don't think there is a "special" tool. I have not done mine but i have never heard about a special tool for taking the drums out!
Old 05-11-2011, 03:18 PM
jkeaton is offline
all you need, if they are stuck is a couple of 9/16 bolts. there are threaded holes you put them in to remove the drum. Shuddering is a common problem on these trucks, not sure if, by 2006, they got it fixed. I know there was a tsb where they replaced the axle and drums, etc.
Old 05-11-2011, 03:59 PM
wingman_214's Avatar
wingman_214
wingman_214 is offline
Adjust the brakes in as far as you can then grab the bfh to loosen it up.
Old 05-11-2011, 07:33 PM
atthewmartin114's Avatar
atthewmartin114
atthewmartin114 is offline
if there new they should slide off with a few good smacks with a hammer. if that even.
and your shake your should check the ledge that pads sit on most places wont fill in the holes that are created i just filled the holes with a welder and grinded mine smooth. my shake went away
Old 01-14-2012, 05:10 PM
Boris1059's Avatar
Boris1059
Boris1059 is offline
@ ericemery
The drums on my '99 were stuck tight. Didn't think I was going to get them off.
Followed your advice (Heat, beat and got a BFH) and they are off.
No pads left either side....Don't think the Hubs have ever been off (80K miles).
Thanks
Old 01-14-2012, 10:42 PM
graythang's Avatar
graythang
graythang is offline
I barrowed a drum puller and it worked well. They where rusted on the hubs. Backing out the shoes will not make a difference but that is a normal procedure anyway. Do not bang them off that may cause damage to the axel bearings. Changing the rear brakes including the drums make a big difference in the shutter problem. The drums become out of round and run out is beyond correction.
Old 02-17-2012, 12:10 AM
jwebbz's Avatar
jwebbz
jwebbz is offline
I am changing the shoes on my '06, drums came off, shoes went on, and now the drums won't go back on. Any ideas? My neighbors and I have tried everything we know of. Any help would be appreciated. I lose my secondary vehicle in a few days!
Old 02-17-2012, 07:19 AM
Eimer123's Avatar
Eimer123
Eimer123 is offline
You need to adjust the brake pads in. The new pads are larger the on the warn down ones.
Get the5000+ page service manual from
https://dodgeforum.com/forum/3rd-gen...s-manuals.html
Its just to hard to explain how to adjust them.
Quick Reply: 2006 Dakota Rear Drum Removal
