Changing spark plugs in a 4.7? I swear I did a search
Old 05-11-2011, 02:08 PM
jgd2305's Avatar
jgd2305
jgd2305 is offline
Default Changing spark plugs in a 4.7? I swear I did a search
I did a search and couldn't find the answers to my questions, so here they are:
1. Is changing the plugs on a 2004 1500 4X4 with a 4.7 just as straightforward as pulling the old plugs and replacing them with new ones? I understand the hemi's are a pain, so I'm just wondering how the job is on a 4.7. Do I need a torque wrench? How many pounds should I torque them to?
2. Is it ok to spray a little pb blaster on the plugs the day before to hopefully loosen them up? The last thing I want to do is wreck the threads trying to remove them.
Thanks
Old 05-11-2011, 02:30 PM
Lowrider82's Avatar
Lowrider82
Lowrider82 is offline
I had no problems on mine. I have a 2008 though. There simple. The only problem I ran into was finding a spark plug socket to fit down the shaft where the spark plug is. Almost got one stuck cause it was a little to fat. Luckily I had like 5 different sockets. I used a 5/8 I believe to remove them
Old 05-11-2011, 09:19 PM
tafet's Avatar
tafet
tafet is offline
Its not that difficult on the 4.7. We only have 8 plugs. The last 2 on the passenger side are the most difficult. The plugs shouldn't be smoked down were you should need any bp blast. I don't have my manual with me. Plugs don't get a lot of torque. Make sure you put some anti seize on the threads before you reinstall the plugs. The best socket would be a 5/8 spark plug socket, but you can use a piece of vacuum tubing to start the plugs. You find a piese that will fit snuggle around the insulator. Its best to start them by hand so you can tell that they have start smoothly. I think I got most of the basics. Maybe someone else will chime in with the torque.
Old 05-11-2011, 09:24 PM
truegent81's Avatar
truegent81
truegent81 is offline
for the specifics on the torque, and any other specific questions, i would download the manual for your truck. you can go to weeds page and get them from his sig or do a search for it.
i am not advanced as i would like to be and this manual is pretty detailed. i actually read it during down time. i just wish i had the tools and space :|
oh yea, +1 on the tubing to start the plugs. i have a 12' piece of 3/8' tubing i believe in my tool box. always nice piece to have and for only a few cents from AZ
Old 05-12-2011, 07:46 AM
tmh462's Avatar
tmh462
tmh462 is offline
Torque on the plugs is 14-16 lb/ft. If you're worried about removing the threads when you remove the plugs, do the job when the engine is cold, that is, before starting the truck in the morning. A dab of anti-sieze on the threads is a good idea. A small dollop of dielectric lube on the plug insulator will help keep the boot from sticking to the plug for next time.
Old 05-12-2011, 10:59 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Although it is good practice to do the proper TQ, I have always snugged mine and did another 1/8 turn.
Old 05-12-2011, 12:07 PM
jgd2305's Avatar
jgd2305
jgd2305 is offline
Thank You guys
Quick Reply: Changing spark plugs in a 4.7? I swear I did a search
