Stratus Coupe SXT 2.4L - Which engine is it?
Old 05-04-2011, 06:14 PM
Chuck80's Avatar
Chuck80
Chuck80 is offline
Default Stratus Coupe SXT 2.4L - Which engine is it?
I've got a 2004 Dodge Stratus Coupe SXT with the 2.4 engine. I can't figure out which version of the engine it has (forgive my ignorance, I bought the car before I even knew what a OHC was). There's no markings on the engine cover.
Rockauto.com lists the choices as:
2.4L 2351cc L4 FI (G) SOHC
2.4L 2429cc 148cid L4 FI (J) DOHC
2.4L 2429cc 148cid L4 FI (X) DOHC
Autozone lists the choices as:
G 2.4L SFI SOHC
J 2.4L SFI DOHC PZEV
X 2.4L SFI DOHC
Wikipedia says the Coupe uses the 2351cc Mitsubishi 4G64
decodethis.com said my VIN's engine is 2.4L L4 DOHC 16V
allpar.com/mopar/vin-decoder.html listed the engine as 3.5L 6 Cyl 24 Valve SOHC!
I know I'm a newbie here, but I did my best to search many past threads for the answer before posting. I'm planning to change the timing belt, and there are different belts for the SOHC and DOHC versions.
So which is it? G, J, or X? SOHC or DOHC?
Thank you!
Old 05-04-2011, 06:59 PM
pearl01stratcpe's Avatar
pearl01stratcpe
pearl01stratcpe is offline
The 01-05 COUPE shares the same engine as the Mitsubishi Eclipse 00-05.
Single Over Head Cam.
The sedan parts in no way shape or form will fit. Sedan is DOHC.
Old 05-04-2011, 07:03 PM
BillS's Avatar
BillS
BillS is offline
the 8th character in vin on dash will tell you g,j or an x
Old 05-05-2011, 12:07 AM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
If you send me a pm with the last 9 of the vin, I can tell you. In fact I'll send you the build codes.
Quick Reply: Stratus Coupe SXT 2.4L - Which engine is it?
