Front brake lock up AGAIN!
Old 04-28-2011, 07:42 AM
CtownChris's Avatar
CtownChris
CtownChris is offline
Default Front brake lock up AGAIN!
1999 D had front R brake lock up in July. Replaced all parts including hoses.
D has 119000 miles and about 6K since last summers brake issues.
Went for a short trip about 7 miles total and noted it felt tight.
When I got home smell burning and wisp of smoke from R front wheel well.
The wheel was HOT compared to L side which was just warm.
What should I do this time. Seems ridiculous to replace everything all over again if the problem may continue to pop up. Do not want this to happen when out of state of with it full of family on a trip.
Why is this happening again.
Frustrated D owner.
Old 04-28-2011, 09:17 AM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
is this a vehicle that you dont drive much? believe it or not but sitting long enough without use can cause rust to build up on the rail where the pads slide, making it so that they dont slide smoothly, this will make them hang up when you let off the brakes and drag (hence heating up that wheel)
Old 04-28-2011, 09:23 AM
DrewsDurango98's Avatar
DrewsDurango98
DrewsDurango98 is offline
if its not the caliber or the caliber pins....i would have to guess one of those valves by the brake booster, becuz its only happening to one tire. never seen those valves break though. i would first make sure that front caliber is moving freely and that the pins are well greased.
Old 04-28-2011, 11:37 AM
CtownChris's Avatar
CtownChris
Little use. It's the 3rd vehicle. Last one used only if needed.
Usually once a week for a short trip if the 2 cars are out.
It's been out weekly at least once.
Thanks for the fast replies.
will pull it apart later today.
Old 04-28-2011, 12:40 PM
srch4me's Avatar
srch4me
srch4me is offline
it sounds like its the caliper but you said you replaced all the brake parts... have you tried re-compressing the caliper that was having issues? might have gotten a bum caliper... i had to do that... replaced both front calipers cause they both took a dump...
Old 04-28-2011, 01:30 PM
Bobman's Avatar
Bobman
Bobman is offline
Water / contaminated brake fluid will cause caliper pistons to set up as well. You may want to consider purging the brake fluid and replacing it. Just make sure that you don't allow any air bubbles to enter the system if you have ABS as it'll require dealer intervention to reset the codes.
Bob
Old 04-28-2011, 02:46 PM
CtownChris's Avatar
CtownChris
Calipers not changed.
Did compress.
Took it apart and put back.
Re-greased everything.
Seems OK.
If it continues to happen will look at purging the brake fluid and/or replace calipers.
No problem driving around the block.
Just a PITA.
Old 04-28-2011, 03:26 PM
Bobman's Avatar
Bobman
Bobman is offline
Did compress.
Seems OK.
Just a PITA.
Could you tell what was stopping the caliper from releasing? It's either not sliding on the bolts or the piston is sticking. Unless your rotors were that rusted from sitting....
Old 04-28-2011, 09:48 PM
CtownChris's Avatar
CtownChris
Rotors NOT rusty.
One bolt was tight in the boot.
Cleaned and greased.
Maybe should LOAD up on the grease.
It was moving freely when I put it back.
How do I check for a stuck piston?
It moved in when I compressed it with my C clamp.
Old 04-28-2011, 10:49 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
+1 Bobman
Sounds like bad fluid.
Also sounds like the pad slides are grooved which causes the pad arms to stick in the groves, that could cause the issue (especially if they have cracks in the new pads in the center).
Quick Reply: Front brake lock up AGAIN!
