ABS Control Module
Old 04-23-2011, 11:36 PM
kuziwr's Avatar
kuziwr
kuziwr is offline
Default ABS Control Module
Why would my control module not be responding??????
Is there any way to test it with a multi meter to find out if its even getting power?
I have all the fuzes and relays in the correct spots under the hood but still i cant figure it out.
Thanks for the help
Rory
Old 04-24-2011, 01:10 AM
J415's Avatar
J415
J415 is offline
What exactly is happening?
Old 04-24-2011, 01:17 AM
kuziwr's Avatar
kuziwr
kuziwr is offline
Nothing thats the problem. I had a new diagnostic tester hooked up to my obd2 port to try and find out the code as to why my break and abs light is on and the reader couldn't even get a signal from my abs control module. And i just want to know if anyone has had this problem or if there is a way to test the module for power
Old 04-24-2011, 01:22 AM
J415's Avatar
J415
J415 is offline
If your brake and ABS light or on, then more likely then not, it's your ABS thats located on top of your rear diff. Do a search for "brake light and ABS light on" and you'll see what I'm talking about. As to your original question, sorry I don't have an answer for you.
Old 04-24-2011, 01:39 AM
kuziwr's Avatar
kuziwr
kuziwr is offline
I already replaced it, the problem is that the reader couldnt even recognize an abs system
Old 04-24-2011, 02:48 AM
J415's Avatar
J415
J415 is offline
Try clearing it by disconnecting you battery for 30 seconds with the lights on. Then go back and see if the light still kicks on. If that doesn't work, get your Haynes manual and turn to page 9-24and read the "Diagnose and Repair" section. That ought to give you some more insight as to what's going on. Best of luck.
Old 04-24-2011, 08:27 AM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
the abs control module is a black box near master cylinder. might have kelsey hayes stamped or printed on it. there's likely a fuse for it, either under the hood or in the end of the dash. should be an electrical connector to it. you could gently probe the pins for power.
download the 01 service manual in the faq section. it has very good wiring diagrams in the back.
Old 04-24-2011, 08:31 AM
His truck is a 97, so, chances are very good that the average code reader is NOT going to talk to the abs. Also, he probably only has RWAL..... so not much of a controller in any event. Not like the system works worth a damn.
Old 04-24-2011, 08:40 AM
dhvaughan's Avatar
dhvaughan
ah..
i'm thinking about disabling mine.. i had to slam on the brakes the other day for an emergency stop and the stupid thing released so many times i thought i wasn't going to get stopped in time.
Old 04-24-2011, 08:48 AM
Mine doesn't work worth a damn. I can lock the rear brakes easily. And none of the fault indicators are on....... I really don't see the point of it being there at all. Probably a marketing gimmick.
Quick Reply: ABS Control Module
