1986 W350 4x4 --> GVWR ???
Old 04-23-2011, 11:16 AM
kc8mln's Avatar
kc8mln
kc8mln is offline
Default 1986 W350 4x4 --> GVWR ???
Anyone know what the GVWR (gross vehicle weight rating) is on a 86 W350 4x4??? I need to know what the max payload capacity for the vehicle is per manufacture specs for the DOT office. I have tried google searches, but found no info on this so far and the dealer couldnt help me as the records dont go back that far on the GVWR on the trucks...Anyone got an actual spec book on this or someplace that I can get a copy of verifiable proof for the DOT office?
PS:-> I'm also looking for the GVWR of the 1985 too, but I'm betting that it will be the same.
~Thanks
Old 04-23-2011, 02:34 PM
SEAL's Avatar
SEAL
SEAL is offline
It is posted on the drivers side door jam.
Old 04-23-2011, 05:40 PM
crazzywolfie's Avatar
crazzywolfie
crazzywolfie is offline
ramcharger central has a vin decoder that might give you a general idea of what the GCWR if it is not on the door jam.
Old 04-23-2011, 11:24 PM
wontacceptthis's Avatar
wontacceptthis
wontacceptthis is offline
Single wheel or dual? I have a buddy with an 84 srw. I'm almost positive his is 8600#. Danas front and back. 727. 360.
Old 04-24-2011, 01:10 AM
SixGun's Avatar
SixGun
SixGun is offline
I believe it's the 4th digit in the VIN.
GVWR:
D= 0001-3000
E= 3001-4000
F= 4001-5000
G= 5001-6000
H= 6001-7000
J= 7001-8000
K= 8001-9000
L= 9001-10,000
M= 10,001-14,000
Chilton's and manual both show the same.
Old 04-24-2011, 06:41 AM
SEAL's Avatar
SEAL
SEAL is offline
SixGun's chart is correct if you are looking for a range. I don't know if the DOT will accept a range. If you want specifics the door jamb is still the best source and DOT can't argue with it.
Old 04-24-2011, 11:47 AM
SixGun's Avatar
SixGun
SixGun is offline
Yep Yep unless your door jamb looks like mine. White unreadable sticker. What were these guys thinking? Years later these stickers are crap when you need them most.
Quick Reply: 1986 W350 4x4 --> GVWR ???
