Neon SRT-4 Dodge Neon SRT-4 is the pocket rocket that took the import scene and turned it upside down.
Spark plug gap.?
Old 07-01-2005, 07:45 PM
CSXT802's Avatar
CSXT802
CSXT802 is offline
Default Spark plug gap.?
what plug gap should I run with Iridium plugs?
Old 07-01-2005, 09:22 PM
PSI Chick's Avatar
PSI Chick
PSI Chick is offline
Default RE: Spark plug gap.?
run the gap that they came with. they come pre-gapped for a reason. which ones you need depends on set up.
Old 07-01-2005, 09:42 PM
roachnigga's Avatar
roachnigga
roachnigga is offline
If you do decide to gap'em be VERY Careful on the electrodes
Old 07-01-2005, 10:12 PM
CSXT802's Avatar
CSXT802
CSXT802 is offline
Thanks for the feed back. I checked the gap on the plugs they are at .051-.052 out of the box. so I'll install them with this gap. it seems a bit big but I have never used this type of plug before.
Old 07-02-2005, 02:33 AM
PSI Chick's Avatar
PSI Chick
what plugs did you get (brand and numer) and what are your mods
Old 07-02-2005, 12:20 PM
roachnigga's Avatar
roachnigga
^^^ YUP...
Old 07-02-2005, 04:43 PM
CSXT802's Avatar
CSXT802
CSXT802 is offline
the spark plugs are Autolite XP Iridium .6mm finewire part # XP5263. ( the advance auto parts in middletown did not stock denso,or NGK.) The SRT-4 is an 05 with 6,000 miles and is bone stock. ( its my wifes car thats why there are no mods yet, but she will give in sooner or later.) The only reason I changed the plugs, is the car would skip or stumble on a cold start and if you put your foot into it at nomal speeds. It did not do this all the time . When I pulled the stock plugs they looked like new, no color on them (lean?) Thanks.
Old 07-03-2005, 10:47 AM
roachnigga's Avatar
roachnigga
i havent heard of anyone using Autolite on their SRT. So i cant reply to how it benifits performance wise. Many pple here uses NGK, Densos, & some still have the factory still install (RR you still have yours). Their are websites, which you already may know, that you can order from. Maybe some has a set and they can better give ya some input.
Peace
[sm=coolness.gif]
Old 07-03-2005, 03:47 PM
PSI Chick's Avatar
PSI Chick
i haven't even heard that autolite made a plug that could fit the srt. are you sure that they are the correct plug? ones for a regular neon will not work in an srt.
Old 07-03-2005, 03:59 PM
CSXT802's Avatar
CSXT802
CSXT802 is offline
the plugs were the same thred length and over all length was the same. I have no way of cross refernceing the heat range. they are in the car now. it seems to run good. so I'll keep you posted If I run into a problem with them. The guy at advance auto said there is a 5 year warranty unlimited milage. so if there is a problem I'll return them.
Quick Reply: Spark plug gap.?
