How do I check for play in ball joints.
Old 04-08-2011, 05:34 PM
cyclone429's Avatar
cyclone429
cyclone429 is offline
Default How do I check for play in ball joints.
I was advised that i need upper and lower ball joints, left side, term used was minor play, also the ouuter tie rod needs to be repalced, how do I check that my self, My Ram is a 2500 06, I have noticed a bit of play in the stearing, but nothing I consider ad normal for a five year old truck, and, why replace only one side upper and lower ball joints, why not do booth the left and right side?
Im at 110,000 Km and axle seals on booth right and left rear are starting to weap, I don't want to sink more $$$ into my truck, as thier will be brake work, possible clutch repair, replacement.
90% of trucks use has been highway
Old 04-08-2011, 08:40 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
You can visually check the ball joint boots for tears. If they are torn then it is time to replace them. You can also lift the tire off the ground and pull the tire up and down to check the ball joints or left to right to check the wheel bearings.
It would benefit you at this point to take the time to click on the links in my signature and download the service manual for your truck as all that and a lot more info is in there.
Quick Reply: How do I check for play in ball joints.
