P0455 OBD-II Trouble Code, 2003 GC
Old 04-04-2011, 12:32 PM
Gabriel51's Avatar
Gabriel51
Gabriel51 is offline
Default P0455 OBD-II Trouble Code, 2003 GC
PO455 indicates a fuel vapor leak or lack of purge flow in the EVAP control system.
I only get this about once a week and only first thing in the morning within about two miles of driving.
I checked all the hoses in the engine compartment ,which are good but I have not checked the ones underneath yet.
The above symptoms my indicate a specific problem that someone may have already experienced?
Anyone ever have this problem?
Also the gas cap passed State inspection two weeks ago.
Ideas?
Thanks
Old 04-04-2011, 01:28 PM
Gabriel51's Avatar
Gabriel51
I went out, put it up on ramps and checked underneath. The only thing I found was the two hoses coming off of the Charcoal canister had broken clamps! The hoses were not loose on the nipples but the white clamps were split so I installed new clamps.
The hoses looked good however the large hose is encapsulated in a sheath and real examination is impossible without removing the hose.
Everything looked new and the hoses were still supple.
We will see in a few days.
Old 04-04-2011, 04:33 PM
Cougar41's Avatar
Cougar41
Cougar41 is offline
Here's a video that shows some likely leak spots and how a shop finds leaks: http://www.youtube.com/watch?v=CSn0ljUS6kI
Old 04-04-2011, 04:58 PM
Gabriel51's Avatar
Gabriel51
Thanks, I had seen that video. The reason I posted here was in hopes of finding someone who would know why this only does this when it has sat over night and within the first couple of miles when driving (but not every time).
If I was familiar with this system I would know why it only does it then,
maybe the pump only runs then? It's not ambient temperature related either.
Old 04-15-2011, 11:34 AM
Gabriel51's Avatar
Gabriel51
I pressurized the system this morning with about 5 lbs of air pressure and checked for leaks. I found none up top, however I could hear the air going into the system where I connected the supply air.
So I crawled underneath and could hear air escaping and it was coming from the charcoal canister. I sprayed (spray bottle with soap and water) all the hoses that were hooked to it and none were leaking.
I looked carefully at the pump that is associated with this system because it is near by plus I read it will vent unless the computer closes it but the noise was coming from the charcoal canister , so I pulled it and found a broken mounting tab.
At first I thought I broke it removing it but closer examination reveled that it was already broken as evidenced by the lighter portion that resulted from pulling it back further. See pictures.
I re-secured it with epoxy and fiber glass cloth for reinforcement.
I will return after a few day for an update...
Old 04-15-2011, 11:57 AM
mfahey's Avatar
mfahey
mfahey is offline
The canister has to be removed for work on another component which I believe is the sway bar bushing on that side. Maybe someone worked on the bushing and got a little carried away on moving it.
Old 04-15-2011, 12:00 PM
Gabriel51's Avatar
Gabriel51
I think you are right because the screw that holds the rear end of the tray bracket was stripped.
It is a sheet metal screw that goes through a rubber bushing.
I went to the next size up.
Old 04-18-2011, 10:57 PM
Gabriel51's Avatar
Gabriel51
Default Problem solved
The above repair corrected the PO455 code...
Quick Reply: P0455 OBD-II Trouble Code, 2003 GC
