1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Help my car wont stop smoking
Old 04-03-2011, 02:29 PM
Mandy31's Avatar
Mandy31
Mandy31 is offline
Default Help my car wont stop smoking
My 95 Dodge avenger smokes really bad out the exaust. What is going on?
Old 04-03-2011, 04:22 PM
bad venge's Avatar
bad venge
bad venge is offline
Section Moderator
Check compression and leakdown ... Either the heads are rebuilt wrong or the cylinders are worn and causing blowby either would show up on a compression test
Old 04-03-2011, 08:34 PM
Mandy31's Avatar
Mandy31
Mandy31 is offline
Hey its a 95 Avenger 2L 4 Cyl and its blowing white smoke not blue.
Old 04-03-2011, 08:36 PM
Mandy31's Avatar
Mandy31
Mandy31 is offline
95 Avenger 2L 4 Cyl. It is blowing white smoke not blue.
Old 04-04-2011, 04:50 PM
bad venge's Avatar
bad venge
Section Moderator
white smoke is steam likely bad head gasket / cracked head ?
Old 04-04-2011, 07:51 PM
Mandy31's Avatar
Mandy31
Mandy31 is offline
Compression Test was great.
Could it be a bad vaccuum line or bad EGR Valve?
Old 04-04-2011, 08:34 PM
bad venge's Avatar
bad venge
Section Moderator
Doubtful
Quick Reply: Help my car wont stop smoking
