rear end gearing
Old 03-30-2011, 06:56 AM
V8DAKOTA's Avatar
V8DAKOTA
V8DAKOTA is offline
Default rear end gearing
How do I find out what rear end gears my truck has?
Old 03-30-2011, 12:38 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
What year is your truck, I can move this thread into the proper location.
Here are some simple instructions.
What gear ratio do I have?
Jack up one tire if you have an open diff, or both tires if you have a working posi or locking differential. Rotate the tire one full revolution for posis and lockers and 2 full revolutions for open diffs. Carefully count the number of full revolutions the driveshaft makes. This is your gear ratio. In other words, if the drive shaft turns 3 ¾ turns, you probably have a 3.73 gear ratio. Turning the tire for twice the number of full revolutions and dividing the drive shaft revolutions by two will give you a more accurate reading.
96 down has a sticker under the hood that lists it. 97-up have a sticker in the glove box that lists it. Or you can request a build sheet from Dodge.
http://www.dodge.com/wccsapp/univers...ull&category=U
Old 03-31-2011, 12:58 AM
V8DAKOTA's Avatar
V8DAKOTA
V8DAKOTA is offline
thanks. i will go and look. it doesn't have any top end. 1998 dakota 5.2 5 speed.
Old 03-31-2011, 02:05 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Do you have larger tires than stock? That is the main reason you would feel a drop in HP. I will move this to the 2nd Generation Dakota Sub-Forum.
Old 03-31-2011, 01:38 PM
dakoman859's Avatar
dakoman859
dakoman859 is offline
i found it was easiest to call the dealer and give them your vin number off the truck thats what i done and they told me what my truck had
Old 03-31-2011, 08:55 PM
V8DAKOTA's Avatar
V8DAKOTA
V8DAKOTA is offline
thanks. no hp loss. it has plenty. it just doesn't have top end. around 95mph. my friend had a 1995 v8 auto and if it didn't have a governor it would probably go 140pmh.
Old 04-01-2011, 05:13 AM
bigreed91's Avatar
bigreed91
bigreed91 is offline
I dont know if its all the dakotas but i know for sure my 5.9 rt is built and geared for low end torque, off the line its a beast, long run though not so much. Its more of a 1/8 th mile truck rather than a 1/4 mile.
Old 04-02-2011, 09:57 PM
V8DAKOTA's Avatar
V8DAKOTA
V8DAKOTA is offline
mine is fast of the line too and just dies at around 90-95 mph. i will probably change the gears.
Quick Reply: rear end gearing
