Dodge Sprinter The Dodge Sprinter is all function, with styling cues from the Dodge Truck line, it makes the workaholic's job much easier. Check out the Dodge Sprinter in showrooms today!
Sprinter p0715 (trans Speed Sensor) T-shooting?
Old 03-21-2011, 01:24 PM
oneshort's Avatar
oneshort
oneshort is offline
Default Sprinter p0715 (trans Speed Sensor) T-shooting?
My wife's 2005 Sprinter went into limp mode (2 & R only) and is showing a p0715 code (Input/Turbine speed sensor A Circuit malfunction). Since the speed sensor appears to be on a control block on top of the valve body, I'm trying to make sure It's truly a bad sensor before I go through the effort of opening up the transmission to replace it. Oh yea, that and the $200 in parts and $170 in fluid.
Has anyone completed this project themselves that could share some experiences, or have any recommendation on how to verify that the speed sensor(s) are actually at fault, and not just a wiring connector for example?
I'd appreciate it.
Old 03-23-2011, 11:43 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Yes i have replace them on the dodge charger with the same transmission. And it did fix the problem. But you could also have a wiring problem too. If you need the pdf file for testing, let me know.
Old 03-26-2011, 09:48 AM
oneshort's Avatar
oneshort
oneshort is offline
Thanks for the offer, that would be very helpful!
Old 03-27-2011, 05:16 PM
master tech
Send me your email addres or post it.
Old 04-26-2011, 04:12 PM
thevandepot's Avatar
thevandepot
thevandepot is offline
`hello i have a 2005 sprinter with code po715 i have changed electric control module two sensers1-05189057aa_1-52108314aa and still have same code after clearing ....any ideas
Old 04-27-2011, 10:32 PM
master tech
Welcome to DF
Do you need the a pdf file?
Old 12-31-2011, 01:41 PM
RickyTalbert's Avatar
RickyTalbert
RickyTalbert is offline
will you send me the pdf file?
Thank
Old 01-02-2012, 10:59 PM
master tech
Sure I can, Send me your email address by a pm and I'll send it.
Old 06-20-2012, 01:44 PM
dcracer92's Avatar
dcracer92
dcracer92 is offline
New Member
master tech, i sent you a pm with my email can i get it to. mine also did the 730 code after it spit the 715 out. thanks for the help.
Old 08-09-2013, 11:01 AM
morris841's Avatar
morris841
morris841 is offline
Default code P0715 need PDF
Yes code P0715 need PDF to check wireing Replaced conductor plate. Still code and in limp mode.
Once changed right part will unit clear limp mode or will I need to take to dealer?
Michel Palmeiro (12-17-2020)
Quick Reply: Sprinter p0715 (trans Speed Sensor) T-shooting?
