what makes the 2003- 2004 dakota lift different?
Old 03-12-2011, 02:33 PM
sl2racer's Avatar
sl2racer
sl2racer is offline
Default what makes the 2003- 2004 dakota lift different?
does anyone know what makes the 2003-2004 dakota quad cab different so much that they don't make a lift kit for it. it would seem like the 2000-2002 would be the same lift kit. as i understand it the transmission is a little different and some electronics but what is different with the suspension?
as i know it my options are body kit/ turn the torsion bar/ or fabricate leaf spring swap to the front and solid axle.
i don't really like body lifts. i like the ride quality i have now and don't want to turn the torsion bar to give up quality. and i have no desire to fab a solid front axle.
has anyone took the 2000-2002 kit and made it work on an 2003?
also i did use the search function but never got an exact answer to these questions.
Old 03-12-2011, 02:43 PM
moparman_2004's Avatar
moparman_2004
moparman_2004 is offline
every thing ive seen is that the 03 and 04s have a diffrent front suspension how idk but i know this is the diffrence
Old 03-12-2011, 06:02 PM
sl2racer's Avatar
sl2racer
sl2racer is offline
i was just under the truck and i just can't think what is is different. looks like a regular run of the mill torsion system.
Old 03-12-2011, 07:36 PM
cowboy63645's Avatar
cowboy63645
cowboy63645 is offline
The difference is the rack and pinion steering.
Old 03-13-2011, 03:27 AM
moparman_2004
well the calipers are diffrent there larger than the earlier ones
Old 03-13-2011, 08:43 PM
hanleysh's Avatar
hanleysh
hanleysh is offline
Pretty sure you're right, I've heard it's all in the front brake set up... They changed
From 02 to 03
Old 03-13-2011, 08:57 PM
sl2racer's Avatar
sl2racer
sl2racer is offline
so the front brakes makes that big of a difference? i though the lift kit for dakotas is a different torsion bar. how do the brakes play a part in the lift?
Old 03-14-2011, 02:53 PM
moparman_2004
what im saying is the front end is diffrent and this is one area where some of the diffrences are. could the tortion bars be bigger maybe redesigned better ball joint set up ?? idk i dont have a 02 and older one to look at, at the moment but when i get home were looking at getting a durango
Old 03-14-2011, 03:20 PM
Blaze10's Avatar
Blaze10
Blaze10 is offline
imo they dont make enough lift options for our trucks when i comes to suspension
Old 03-15-2011, 02:31 PM
sl2racer's Avatar
sl2racer
sl2racer is offline
i know. seems like the red headed step child of the dodge world. even the neon gets more love. haha
Quick Reply: what makes the 2003- 2004 dakota lift different?
