Do downstream o2 sensors effect gas milage?
98 ram 1500 5.2l 2wd. check engine lights come on every week or some after city driving and its always the o2 sensor so my question to you is does the downstream o2 sensor effect gas milage because ive heard its only for emmissions is this true?
That is correct. You can try this to eliminate the CEL. https://dodgeforum.com/forum/2nd-gen...converter.html
Well all kinds of things happen if the cat is clogged. But that has nothing to do with your question about the post cat o2 sensors. Which has already been answered. And from what I've read here, you have no cat(s) anyway. And since gutting the cat will usually result in a loss of low end, you may be on the gas harder to get the truck rolling. Which in turn, will result in worse mpg.
A CEL about the downstream O2 usually means one of two things.
1. The catalytic converter is bad, which doesn't necessarily mean its clogged, but it may be.
OR
2. That O2 sensor is bad.
Like others have said, a bad downstream O2 will not have any effects on performance/MPGs, but you are right that a bad catalytic converter may.
OR
