Electric fan swap
Old 02-24-2011, 06:56 AM
bigred_84's Avatar
bigred_84
bigred_84 is offline
Default Electric fan swap
I have a 98 5.2 4X4 and was wondering if anyone has taken the fan and fan clutch out and replaced it with an electric one. If so what all do I need and how hard is it? Will I see a difference in power and fuel economy? thanks.
Old 02-24-2011, 09:10 AM
Dans01Durango's Avatar
Dans01Durango
Dans01Durango is offline
Here's what we have in the DIY section. HTH.
Stock Electric Fan Replacement
https://dodgeforum.com/forum/1715720-post62.html
https://dodgeforum.com/forum/1st-gen-...-colors-2.html
Auxiliary Electric Fan Motor
https://dodgeforum.com/forum/1st-gen-...ml#post2185445
Here's what a trusted member did to swap out his clutch and electric fans for a more powerful electric one to replace both stock fans:
http://www.durangoclub.com/forum/vie...n+swap&start=0
HTH.
Old 02-24-2011, 11:53 AM
abew330's Avatar
abew330
abew330 is offline
i dont mean to hijack this thread but is it better to have the fan and fan clutch replaced with a electric one?
i know my fan clutch needs to be replaced. am i wonder why dodge didnt use a different setup as oppose to the fan/fan clutch....
Old 02-24-2011, 01:49 PM
WhiteWidow00's Avatar
WhiteWidow00
WhiteWidow00 is offline
It's all personal preference. The error margin for an electric fan is typically higher so I'll stick with my clutch fan.
Old 02-24-2011, 05:04 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
the clutch fan is more reliable, and cools much better for the cost than an electric fan does, if you do alot of towing the clutch fan is your best bet for reliability.
Old 02-24-2011, 11:20 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
If you swap to full electric and remove the clutch fan, you would want to leave the auxiliary electric fan installed as that one engages during A/C use and overheating. I would move it to the front though.
Dodge (or anyone else) doesn't go full electronic fans because most trucks are used for towing and they promote heavy duty use. They are not a car with a trans axle. A clutch fan when fully engaged is going to bring in more air then any fan out there on the market, this will cool that motor faster and that holds them less financial responsibility.
Old 02-26-2011, 07:01 AM
bigred_84's Avatar
bigred_84
i have a 99 which doesnt have any electric fan at all. But thanks for the info. I dont do alot of towing or pulling either it is for my wife to drive the kids around.
Old 02-26-2011, 12:54 PM
hydrashocker
Then no need to relocate the old electric fan as you said. You would just remove the shroud and the clutch fan and install the large E-fan with a temp sensor and relay.
Old 02-28-2011, 01:02 PM
bigred_84's Avatar
bigred_84
thanks everyone
Old 03-10-2011, 11:02 PM
MoparMan1991's Avatar
MoparMan1991
MoparMan1991 is offline
Sorry to revive this but I still don't know what I need to make the mounting brackets completely. This is something I am very serious about doing.
Quick Reply: Electric fan swap
