P0742 Torque Converter clutch circuit stuck on
Old 02-22-2011, 09:25 AM
InterpunX's Avatar
InterpunX
InterpunX is offline
Default P0742 Torque Converter clutch circuit stuck on
Anybody else ever have the (P0742 Torque Converter clutch circuit stuck on) code pop up. I started last year acting up mostly when i was doing towing. I noticed sometimes when say going up a long hill, the overdrive would kick in (torque converter unlocked) and then would stay like that and not lock up again even if i eased on the pedal no matter what it was stuck unlocked and the engine light comes on. But after a while the light disapears and it seems ok, especially when driving with no trailer. Also the truck stalled like 3 times in its lifetime at a red light, which i think is related with the torque converter problem.
But then again lately it started doing it, i notice when it does it right away cause it wont drop RPMs when it should, but the light doesnt come on always, but i check with my trinity and the code P0742 is there. So what i do is pull over, stop the truck and erase the code and then everything is fine until have have a long hill climb or long accelaration periods where the tranny goes into overdrive but doesnt lockup after. Si i just keep erasing the code and its fine, has not done it for a bit and havent had the chance to go to dealership yet.
Anybody ever have this issue or anybody ever experienced this code with any vehicles and if yes what was the solution?
Old 02-22-2011, 11:06 AM
InterpunX's Avatar
InterpunX
Taking it to the dealership today to look at the problem and also to change my plugs.
Old 02-23-2011, 10:07 PM
HEMI2500TRX4's Avatar
HEMI2500TRX4
HEMI2500TRX4 is offline
Default transmission shudder
Did you experience any stumbling shaking or unusual noises when this occured? I was towing and climbing a long steep hill today and thought my truck was falling apart.
Old 02-23-2011, 10:22 PM
InterpunX's Avatar
InterpunX
No noises when this happens.
The only noise i could maybe relate with the torque converter is a rattling (exhaust rattling on frame kind of sound) happening at 1900 rpm about. But that's a different story in a different thread.
What was happening with yours and u have a 2500 Hemi?
Old 03-03-2011, 04:39 PM
InterpunX's Avatar
InterpunX
Update:
Truck was in dealership and they ordered a new torque converter and will have it changed as soon as it comes in.
Quick Reply: P0742 Torque Converter clutch circuit stuck on
