Oxygen Sensor confused!
I am getting error code P0152:
Which means:
2/1 sensor shorted to voltage oxygen sensor input voltage.
Translated (thanks to these forums) basically means "replace h20 sensor passenger side before converter"
Please correct me if I'm wrong as I am no mechanic.
Upon researching again through these forums I found out that NGK also known as NTK is the original OEM oxygen sensor, and seems to be most recommended.
I just give you a quick run down. (my previous exhaust was custom but it failed an out of province inspection) So i purchased a walker Catalytic Converter (with y pipe) Part 56092. Click to see image of my cat
That new exhaust runs down the passenger side to the tailpipe.
I am looking for the sensor that is between the cat and the motor.
I go to NGK website and they have pre cat left, and pre cat right. I assume mine was pre cat right reg club cab (even though mines technically a crew cab.) since my exhaust is on the passanger side.
The link to NGK/NTK H2O sensors for my truck
I do a few searchs on NGK 23135 (pre cat right).. and its seems this is compatible with my truck but just to double check i checked NGK 23137 (pre cat left) and this too is compatible with my truck.
Since I believe I only have 2 sensors
1 pre cat also known as upstream and,
1 post cat or downstream
which of these 2 are the correct OEM product? NGK 23137 or NGK 23135
They make these parts lists so confusing i swear..
I would prefer purchasing something cheaper but I have read oxygen sensor can be different amps ect. and overall I just want one that is reliable, and give me the best possible fuel millage.
Any tips?
Which means:
Any tips?
Ok I wil shorten this up a bit.
Is this the 2/1 o2 sensor port for my truck.My truck specs in signature.
Uploaded with ImageShack.us
And what NTK o2 sensor is for my truck ( need the 2/1 o2 sensor)
NTK 23137?
or
NTK 23135?
PS. have error code p0152
NTK 23137?
or
NTK 23135?
Do both sensors have OEM wiring connectors or is one the type where you have to splice the wires? You have to be careful ordering them to get the OEM connector if that is what you want, definately easier. I don't know what the 2/1 means, but my truck had one pre cat and one post cat sensor.
I ordered my NGK/NTK O2 sensors through Oxygensensorsplus.com and they were definately cheaper. Got both sensors for about what I would have paid for one and free shipping. You can also call them and they will help you determine what is needed for your truck.
"2/1" means 2nd cylinder bank (presumably 4-6 or 4-8), 1st sensor (pre-cat). "V" engines have at least 4 sensors, one pre-cat and one post for each cylinder bank. Pre-cat sensors measure unburned fuel to allow the ECU to determine what fuel mapping should be used. The post cat sensor measures unburned fuel after running through the cat so the ECU can determine the difference pre and post cat, IOW, is the cat doing its job. The signals are in the form of a voltage between 0.1 and 1 Volt and fluctuate like a sine wave, usually in the range of 0.3 and 0.8 volt, + or -. When O2 sensors start to reach life expectancy (roughly 80k miles) they tend to slowdown (like an older person slows down with a walker). Normally they fluctuate twice per second but may slow to once every five seconds, resulting in codes like sensor stuck high (or low), or sensor out of range, etc. The only remedy is replacement. If one is failing, likely the other will be shortly. Your mileage will suffer with faulty O2 sensors as the ECU will ignore sensors producing codes and will remap fuel to default settings, often running rich to protect from a perceived lean condition. As far as your question which sensor to use, that would depend on whether your new exhaust arrangement has the "left" or "right" bank sensors now. It is likely that either will fit/work, but if there is a difference between left or right (bank 1 or 2) sensors then you will need to determine which you are using now. Does the current one have any labeling?
Does the current [o2 sensors] have any labeling?
Also I'm curious is my truck a california emion truck? I found this label stuck to the hood of my truck
And if it is that means I would need a different O2 sensor....
If it helps at all the passanger lside of my motor = 2,4,6
and driver (right) side = 1,3,5
Your hood sticker seems to indicate that you have California-type emissions. California-type emissions are not limited to just California by the way; some other states have adopted "The People's Republik of Kalifornia's" absurd regulations as well. For example, my truck has California-type emissions here in Maine, which is something known as "Northeast emissions" which went into effect for LDVs (light-duty vehicles) in Maine and a few other northeast states in 2001 (lucky me).
If you do have California-type emissions, then you should have 3 catalytic converters and 4 O2 sensors, like this:
The 4 O2 sensors mount before and after the two mini-cats.
The NTK part numbers for the California-type emissions (3 catalytic converters and 4 O2 sensors) are as follows:
Pre-cat left (driver side, AKA: 1/1) - 23137
Pre-cat right (passenger side, AKA: 2/1) - 23135
Post-cat left & right (1/2 & 2/2) - 23132
If your truck did indeed come equipped with the normal federal-type emissions (single cat / dual O2 sensor setup like the Walker 56092 setup you installed), then it would be as follows:
Pre-cat - 23138
Post-cat - 23141
You could install those two O2 sensors (23138 & 23141) into your Walker 56092 setup, but if your PCM is expecting the 4 O2 sensor setup, it may not like it.
Are you 100% sure about that? I have a V6 and, I have only 2 I know of but, I do have 4 plugs 2 of which have the "pad looking" circuit completer on them(notice its labeled R/R (it looks like r/f but its R/R)
I'm guessing that those "circuit completers" are a workaround, as I doubt the factory would have 4 O2 sensor plugs in the harness and then bypass 2 of them (anyone can feel free to correct me if I'm wrong). I'd think it is almost certain that your truck originally came with 4 O2 sensors and the tri-cat setup like in the picture I posted.
This s what i was scared of once I really looked into this.. I already dumped almost 2k into this truck ( new cat, almost all exhaust, wipers, break drums, break shoes, Battery mount, plug wires, tune up, fluids, clockspring, filters)and I truly cant afford to go buy a second cat and start all over from scratch. I figure you may be right and because my error code is spewing 2/1 error code and I do also believe my truck is California so I ordered 23135 sensor and I'm hoping I can "fool" it into thinking the sensors are all hooked up.
You are probably going to have a problem plugging it in though, because your catalytic converter setup has the O2 sensor threaded bosses in completely different locations than the California setup, and the wires coming off the 23135 O2 sensor are short (because the California setup 2/1 boss is pretty close to where the O2 sensor needs to plug in). You could splice in wires to make them longer though (use splice caps with a quality crimper, i.e., an anvil-type crimper).
And yeah, now that I think about it, you definitely are supposed to have the California setup with 4 O2 sensors, simply because of the 2/1 code. On the federal setup which only has 2 O2 sensors, there is no 2/1, only 1/1 and 1/2. From the FSM:
NAA Emissions Package: Two sensors are used:
upstream (referred to as 1/1) and downstream
(referred to as 1/2). With this emission package, the
upstream sensor (1/1) is located just before the main
catalytic convertor. The downstream sensor (1/2) is
located just after the main catalytic convertor.
NAS or NAE Emissions Package: On this emissions
package, 4 sensors are used: 2 upstream
(referred to as 1/1 and 2/1) and 2 downstream
(referred to as 1/2 and 2/2). With this emission package,
the right upstream sensor (2/1) is located in the
right exhaust downpipe just before the mini-catalytic
convertor. The left upstream sensor (1/1) is located in
the left exhaust downpipe just before the mini-catalytic
convertor. The right downstream sensor (2/2) is
located in the right exhaust downpipe just after the
mini-catalytic convertor, and before the main catalytic
convertor. The left downstream sensor (1/2) is
located in the left exhaust downpipe just after the
convertor.
convertor.
