Window Hinge pin removal
Old 02-14-2011, 04:44 PM
TheDirtySanchez's Avatar
TheDirtySanchez
TheDirtySanchez is offline
Angry Window Hinge pin removal
Sombody please tell me there is a Right way to remove the window hinge pin, WITHOUT chipping or cracking the glass in the small square windows that pop out .
92 Ram B250
Old 02-14-2011, 09:45 PM
landyacht318's Avatar
landyacht318
landyacht318 is offline
I once used a beautiful tool similar to a bicycle chain tool to push out the pin. It did not work.
I wound up using my dremel with a thin diamond coated cut off wheel to cut the pin on both sides.
Similar to this:
After This I was able to remove the hardware from the glass and use a hammer and punch to remove the 3 sections of pin that remained.
I now just use regular cotter pins, and can easily remove any of the 4 pop out windows in under a minute.
Certainly makes tinting those windows much easier too.
Old 02-15-2011, 05:53 PM
TheDirtySanchez
sweeeeet
Old 02-15-2011, 05:54 PM
TheDirtySanchez
I got another window today at the junkyard, they has soooo much stuff ,there was another whole Van there & I wanted it all...lol
Old 02-18-2011, 07:21 PM
d2fel's Avatar
d2fel
d2fel is offline
Location: http://www.facebook.com/home.php?#!/profile.php?id=100000188795062
Thumbs up
I just cut mine with a dremil and it's awesome, super easy to take in and out and seals up perfect. thanks! I was always curious about doing that and now its done. less than ten minutes and a quick trip to the hardware store! epic
Old 02-18-2011, 09:56 PM
landyacht318
All hail the mighty cut off wheel and rotary tool!!!!
Old 02-22-2011, 05:58 PM
TheDirtySanchez
Exclamation
That worked !!!!!! and I used these quick pins from Home depot
Old 02-22-2011, 07:09 PM
landyacht318
Nice pins. My cotter pins need pliers and a little persuasion to remove.
Quick Reply: Window Hinge pin removal
