overhead "remote controls"
Hi.
Soon after I got my 2001 Durango last month, I was reading the owner's manual, and noticed that it has 3 buttons overhead that can be programmed to perform "remote control" operations.
I thought it'd be nice to program one of them to my garage door opener. I followed the instructions, and it did not work.
I.e., it says to press the two outer buttons simultaneously to wipe the memory, and then to depress one of the buttons, and the garage door opener (GDO) button simultaneously, with the GDO remote less than 3 inches away. Once the light is lit, it should work-- didn't happen.
Everything worked as it describes-- lights lit up, flashed as stated-- but no GDO operation.
My opener is 3 or 4 years old, so it should work with this, right? Or is the Durango's programming too old to recognize newer models?
Has anyone ever figured out how to do this and get it to work?
I wouldn't be surprised if it's something simple, so that's why I'm asking.
Thank you.
Thank you.
you have a 'learn button' on your garage door opener, after you program the remote into the durangos built in system, you need to follow the learn procedure for the garage door opener to make it accept the code from the durango, your truck is working fine, you just need to tell your garage door opener that the specific signal coming from the durango is in fact allowed to open the garage door. This is because many new systems have rolling code transmitters which are more secure than the older frequency modulated openers, however the durangos built in system cannot replicate that, it will send one code which you then need to tell the garage door opener to respond to
try that and get back to us i had to do this for both of our garage doors and one of them is well over 10 years old
Ok, I had to buy a replacement remote last month so I remember the learn button on the actual GDO unit in my garage.
However, as I remember that, I had to do something similar-- hit both buttons simultaneously-- I'm not that fast in jumping off a 6 foot ladder, and running to my durango and depressing that button too. Plus the reaction to my body jumping off a ladder would cause other problems too....
So, if I programmed the durango's overhead remote before, it's just a matter of now learning my actual GDO unit?
I've been through this programming process a few dozen times, both with my own vehicles and helping friends with theirs. It really is a LOT simpler and quicker with two people. And it definitely gets more complicated and confusing as the machines involved get newer. (old vehicle and old garage door opener = easy. new vehicle and new opener = Pain In The ***...)
im tall enough (and our garage ceiling is low enough)(the durango only has a couple inches of clearance height wise getting in the garage) that i can read the learn button on both of our machines from the ground, i can push the button and still have enough time to run back to the truck and push the button i want to open that door
Wouldn't it be simpler to just have a buddy help you out? In my experience the mention of a fresh 12-pack in the fridge makes it pretty easy to get someone to drop by for a few minutes...
I mean, what starts off a romantic Valentine's Day evening better then saying, "Honey, I need your help out in my garage so I can get the [expletive deleted] garage door opener in your Durango working..." No mention of 12-packs necessary.
OR... you could just remind your spouse that the pre-nup explicitly outlines her duties as "Garage Assistant, As Needed."
You could do one more up and tell her the pre-nup's her Valentines gift!.....
