Fuel Gauge not working.
Old 02-06-2011, 12:49 PM
95neon1025's Avatar
95neon1025
95neon1025 is offline
Default Fuel Gauge not working.
ok i just bought a 1995 ram like two days ago from a buddy well for the past 6 months the fuel gauge has not worked. what could i do to fix it. Info in sig
Old 02-06-2011, 02:32 PM
Check the wiring at the tank, also, does the gauge test when you turn the key to start? (do the gas gauges do that trick??? I never paid attention......)
Old 02-06-2011, 03:12 PM
Silver_Dodge's Avatar
Silver_Dodge
Silver_Dodge is offline
Since it is a Ram, it will be on E most of the time anyway, so it is probably better the way it is so you don't have to see how much gas you are actually using.
Old 02-06-2011, 03:30 PM
newman1367's Avatar
newman1367
newman1367 is offline
replace the sending unit, wiring and gauge. That should do it.
Old 02-06-2011, 03:35 PM
VEETEN's Avatar
VEETEN
VEETEN is offline
Thanks I just shot beer out my nose Silver.
To the OP
there was a recent thread on here recently by 95ram360 about the sending unit float hanging up on the side of the tank.
I'd try to check that first before replacing the whole unit....Cheaper too.
EDIT
https://dodgeforum.com/forum/2nd-gen...-question.html
His was stuck on full though..
Quick Reply: Fuel Gauge not working.
