Anyone replaced the license plate light?
Old 01-30-2011, 03:32 PM
coreybv's Avatar
coreybv
coreybv is offline
Default Anyone replaced the license plate light?
OK, just got pulled over for the second time last night for my rear license plate light not working. Luckily no tickets yet, but I'm sure that's just a matter of time.
Have the new bulb in hand, but I can't seem to get to the old one. My Hayne's manual says to just reach up behind the bumper and twist the bulb holder to remove it. Problem is there's not enough room. I can get my fingers on it, but not enough to get a grip and twist it, and there's also not enough room to get pliers in there.
Any tricks to this? (It's a 98...)
It's about 33 degrees out, so the snow's melting and I'm having to lay down in freezing cold running water to get at the backside of the bumper, so if there's an easier way that I'm missing, I'd rather not lay there and fight with it any longer than necessary.
Old 01-30-2011, 03:36 PM
L7D4N's Avatar
L7D4N
L7D4N is offline
On my 2001, there's 2 screws that hold it to the bumper. Remove the screws and you can slide the entire housing out to replace the bulb.
It's a PITA, but I don't know too much about the 98-00 stuff, so this may be irrelevant.
Old 01-30-2011, 03:55 PM
c4715's Avatar
c4715
c4715 is offline
Same here, 2 screws. But instead of pulling out towards you, push in, then you will reach the bulb. Twist out and replace.
Old 01-30-2011, 04:56 PM
coreybv's Avatar
coreybv
coreybv is offline
Awesome, that worked. Had to take my wife's hair dryer out to thaw the ice out of the screw heads, and one screw broke while taking it out, but once the whole assembly was loosened up replacing the bulb was a 10 second job.
Thanks. I hate the cold, and you guys just saved me a severe case of frostbite on my butt cheeks. LOL....
Quick Reply: Anyone replaced the license plate light?
