Headlight Adjustment Location?
Old 01-28-2011, 10:34 AM
kwanczyk's Avatar
kwanczyk
kwanczyk is offline
Cool Headlight Adjustment Location?
i got a 2006 Dakota 4.7 SLT Quad Cab loaded with stuff, HID conversion, TB spacer, Injen Cold Air, Westin Brush Guard, Jet Chip stage 2, Flowmaster 40 catback. KC Daylighters
i just need some help with finding the adjustment screw for the headlights... there not even and i would like to even them out.
Thanks
Old 01-28-2011, 10:52 AM
lghtngblt02's Avatar
lghtngblt02
lghtngblt02 is offline
The RAM Administrator
Thanks
If you look at the lower inner corner of each light near the grille... there is a little curved cutout spot on the bottom edge of the light. There is a T(I dont remember the size star bit) that you can turn CW or CCW depending on the direction you need... again I dont remember which direction you need. Just mess with it. It doesnt take much to make them move... let me see if I can find a pic...
Old 01-28-2011, 10:59 AM
jkeaton is offline
The only adjustment is up and down. No side to side. Bolt is correct. Adjustment screw is located on the inside (grill side) edge of each light.
Old 01-28-2011, 11:06 AM
lghtngblt02
Heres a pic...
Old 01-28-2011, 01:55 PM
Dinger838's Avatar
Dinger838
Dinger838 is offline
do you notice anything with the stage 2 chip? i had a 1 and alls it was is a paper weight
Old 01-28-2011, 03:10 PM
kwanczyk's Avatar
kwanczyk
kwanczyk is offline
Default chip
i do notice alot better acceleration and low end torque, but im not sure if its from the chip or the intake and spacer. they were all installed at the same time.
Old 01-28-2011, 03:11 PM
kwanczyk's Avatar
kwanczyk
kwanczyk is offline
Default Thank you very much.
Originally Posted by lghtngblt02
Heres a pic...
thanks a lot, i appreciate the time put in to help me out.
Old 01-28-2011, 04:06 PM
lghtngblt02
No worry anytime!
Btw any pictures of your truck?
Old 01-28-2011, 04:32 PM
kwanczyk's Avatar
kwanczyk
kwanczyk is offline
Default pics
No worry anytime!
ill get some when i can. Im in up in the upper peninsula of michigan right for school. theres like 4 feet of snow, as soon as the weather gets nicer i will go clean it off and take some.
Quick Reply: Headlight Adjustment Location?
