PO420 code
Old 01-27-2011, 01:18 PM
Jamie71's Avatar
Jamie71
Jamie71 is offline
Default PO420 code
Hey, i have a PO420 code, i know what it is but I dont know where it is located on the exhaust. Catalyst System Efficiency Below Threshold (Bank 1). Any help would be great to where it is located.
Old 01-27-2011, 01:31 PM
dodgeboy1979's Avatar
dodgeboy1979
dodgeboy1979 is offline
i believe that is the precat o2 sensor. Probably time to change both of them out if they are old
Old 01-27-2011, 01:33 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Along with the plenum and cat.
Old 01-27-2011, 01:37 PM
Jamie71's Avatar
Jamie71
Jamie71 is offline
So the o2 sensor before the cat converter? I think there are 2 of them right?
Old 01-27-2011, 02:35 PM
pcfixerpro's Avatar
pcfixerpro
pcfixerpro is offline
No, dodgeboy1979 is incorrect. It is the post-cat sensor. And to answer your question, yes there are two sensors in a non cali emissions truck.
Old 01-27-2011, 03:07 PM
Maxx_Magnum's Avatar
Maxx_Magnum
Maxx_Magnum is offline
Jamie, is your cat hollowed out by any chance? My cat is gutted and I occasionally get the P0420 code because of it. If I don't clear it myself it usually goes away after a while. If your cat isn't gutted, it may be getting plugged. 90% of the time it's the cat at fault, not the O2 sensor.
Old 01-27-2011, 03:30 PM
Jamie71's Avatar
Jamie71
Jamie71 is offline
My code doesnt go away unless i clear it and I am trying to figure out where behind the cat converter is the bad o2 sensor since it is the Catalyst System Efficiency Below Threshold (Bank 1).
Old 01-27-2011, 03:34 PM
Should be shortly behind the cat. If it isn't there.... that would explain a lot. Shouldn't be more than foot or so away. Might be on top of the pipe.
Old 01-27-2011, 04:53 PM
zman17's Avatar
zman17
zman17 is offline
A 420 code is the one before the cat.......
Old 01-27-2011, 04:59 PM
P0420 1/1 Catalytic Conv Eff
Wonder if it is referring the cat, or the sensor..... not what I would really expect to see for a failing O2 sensor.... but then, it IS a dodge.....
Quick Reply: PO420 code
