Transmission Pan Bolts
01-23-2011, 05:02 PM
on
Hi
Can someone give me the torque specs?
I've recently just did a flush and had a bolt welded on but i am still leaking slowly,
thank you
01-23-2011, 08:08 PM
276 inch lbs. I don't think tightening the bolts will make any difference if they are already snug.
01-23-2011, 09:34 PM
Site Moderator & Tech
Welcome to DF
Are you using a pan gasket or RTV? I torque the pan bolts to 15 to 20 ft pounds.
01-24-2011, 08:13 PM
Alldata shows 13 ft. lbs. I'm assuming you use an alternating pattern when tightening the bolts starting with two bolts opposite each other and then working around in the same direction.
