Transmission wont go into Park
Old 01-17-2011, 02:22 PM
gearjammer95's Avatar
gearjammer95
gearjammer95 is offline
Default Transmission wont go into Park
1997 Ram 1500 4X4 5.9 liter with 200K miles.
Automatic wont shift into Park at all. The linkage seems to be moving freely. It feels like all gears shift OK. I plan to drain pan and see if anything is broken and laying in the bottom tomorrow. Anybody have this happen before? Not sure what could be blocking it from shifting to park?
Any ideas???
Old 01-17-2011, 02:56 PM
HeyYou is online now
Shift linkage out of adjustment? Little plastic caps/cups/whatever worn allowing to much slop? When you think you have it in park, does it go in reverse instead?
Goodwin1989 (10-04-2021)
Old 01-17-2011, 03:01 PM
UnregisteredUser's Avatar
UnregisteredUser
UnregisteredUser is offline
Before you drop the pan, get under there and remove the linkage to determine if you can shift it into park at the transmission with the linkage off. If so, it's a linkage problem.
Old 01-17-2011, 03:47 PM
gearjammer95
I am not sure how to adjust linkage. The linkage looks pretty good at all connections. I will disconnect the linkage off steering collum and see if I can pull linkage up all the way.
The lever does stop at "R" wont go all the way up to park. I read that there is a lever that could break in steering collum. I also have a 1995 Ram 2500 4x4 as a work truck. On that truck I can shift in and out of park without touching brake. So, could something in steering collum prevent it from shifting to park?
Old 01-17-2011, 04:19 PM
Only if something is broken.
Old 08-27-2014, 08:56 PM
midniteshadow's Avatar
midniteshadow
midniteshadow is offline
Default my dodge wont go into park
my 1995 dodge dakota wont go in to park i have remove the linkage and its not that its in the transmission so what would i be lookin at
Old 08-28-2014, 09:47 AM
Pull the pan, and have a look. See if anything is obvious. There is a linkage inside the trans for park.... something may have fell out of place.
Old 01-05-2021, 07:39 PM
Michael Lococo's Avatar
Michael Lococo
Michael Lococo is offline
Default 96 Dakota SLT Club Cab 4wd wont go into Park and can't remove key
My truck is doing the same thing.What can it be?
Old 01-06-2021, 10:13 AM
Many things. How is the external linkage? If you disconnect it, can you shift the trans into park down at the trans itself?
Quick Reply: Transmission wont go into Park
