Old 08-05-2015, 12:32 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: 4WD
Print Wikipost
transfer case fluid change
Old 01-17-2011, 11:55 AM
BigRedRam95's Avatar
BigRedRam95
BigRedRam95 is offline
Default transfer case fluid change
I am going to change the fluid in my transfer case soon is there anything special I should do? How much fluid will it take I could not find it in the owners manual. What brand fluid should I use? Also thinking about putting in a tcase saver what are your guys thoughts on those? Thanks
Old 01-17-2011, 11:59 AM
All a good idea.
T-case saver is an excellent idea. (some would say Requirement.)
ATF +4. Use the same fluid you put in your trans...
NP231 supposedly holds 2.5 pints...... Seems kinda low to me...... but hey.
Old 01-17-2011, 12:04 PM
BigRedRam95
Any idea where the best place to get a tcase saver is
Old 01-17-2011, 12:10 PM
matty675's Avatar
matty675
matty675 is offline
Old 01-17-2011, 02:06 PM
mjonesjr's Avatar
mjonesjr
mjonesjr is offline
I just did the fluid change out in my transfer case. It took about 1.5 quarts to get the fluid running out the fill hole.
Like said above, ATF+4 is what goes in the transfer case.
Old 01-17-2011, 03:07 PM
UnregisteredUser's Avatar
UnregisteredUser
UnregisteredUser is offline
Definitely put in a Transfer Case Saver. It's cheap insurance to prevent this:
Originally Posted by CappinHoff
Old 01-17-2011, 03:38 PM
Silver_Dodge's Avatar
Silver_Dodge
Silver_Dodge is offline
When I do mine, I buy about twice the fluid I need or more. I drain out the old fluid, then I put half of the new fluid in a squirtable container and squeeze that fluid into the t-case fill hole. It immediatly runs out the drain hole, but it runs out very dirty. I keep squirting it in until it runs out clean. I just think this gets rid of a lot of the dirty fluid that is still in the t-case that doesn't come out by just draining it. Then I close the drain plug and fill it up to capacity with the rest of the brand new fluid. I use ATF+4 in mine.
Old 01-17-2011, 09:17 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
drivetrain.com is the only place i've seen the tcase saver. if anyone can find it anywhere else let me know. its damned expensive at drivetrain.
here's some tips -
1. the hex key is 10mm, don't use 3/8 inch it will strip out the center of the SOFT aluminum plug.
2. remove the FILL plug before removing the DRAIN plug. can you guess why. re-read #1.
3. it takes about a quart of ATF+4 to refill a 1500/231, maybe 1-1/4.
4. apply some liquid teflon or rtv to the drain and fill plug threads and just snug them when reinstall. don't torque them to 40 pounds. see #1.
5. the tapered squirt cap from a bottle of gear oil works good for squirting the oil in the fill hole of the t-case (and the diff). i always save them from the gear oil bottles.
Old 01-17-2011, 09:49 PM
UnregisteredUser
I've hunted high and low and have never found another source. I can't even find a web site or reference information for the manufacture, Gilly's.
$50 ain't all that bad, really. I traded 'em a new TV cable for the one they broke on my truck and saved three bucks.
Quick Reply: transfer case fluid change
