Oil filter size?
Old 01-17-2011, 01:04 AM
terracedean's Avatar
terracedean
terracedean is offline
Default Oil filter size?
According to the Fram oil filter guide at canadian tire there are 2 sizes of oil filter for my 08 1500 hemi? how can i tell what size i need without taking it off and then going to go and get one?
Old 01-17-2011, 07:41 AM
NHHEMI's Avatar
NHHEMI
NHHEMI is offline
1 - NEVER use Fram filters. They are garbage(IMHO)! You can get better filters for the same or even less money( in the US anyway ). Even if you only have Fram available to you in the aftermarket up there( have heard it is hard to get other aftermarket brands in Canada )spend the extra and go to a dealer for a MOPAR filter or order a bunch of what you need from an online source like Amazon.com( they have good bulk deals at times on many different filter brands ). Actually, even though Motorcraft filters are OE for Ford they are excellent quality filters. The MTC FL820 or FL820S are used on a ton of Fords and it is the correct filter for the 08+ 4.7L and 5.7L. I would use a MTC filter in half a heart beat before using a Fram "Orange Can Of Death"(JMPO).
2 - There is only one size for 2008+ 5.7L and it has a metric 22X1.5 MM thread. Starting in 2008 the 4.7L and 5.7L got a new filter. Here are some numbers to have for cross reference. Please don't use a Fram. They are really poor quality filters IMO
2008+ 4.7L & 5.7L Filter #'s( in no order of preference ):
MOPAR = MO899
WIX = 57899( is the Wix application # but 51372 also works and is the cross # from the MOPAR filter )
NAPA GOLD( same filter as a Wix ) = 1372
ROYAL PURPLE = 20-820
K&N = HP-2010
MOBIL 1 = M1210
AC = PF1250
BALDWIN = B329
CHAMPION LAB's = PH820
MOTORCRAFT = FL820/FL820S
PUROLATOR = L24651
PUROLATOR PURE ONE = PL24651
BOSCH = 3410
BOSCH DISTANCE PLUS = D3410
HASTINGS = LF110
Obviously this is not all of the filters out there. They are all quality filters hyowever. Some better than others but any of these are a good filter to use. It at the least gives you a good list to search from or use for cross reference. Again, IMPO, Fram filters are awful so avoid them at any cost barring desperation. The filter from Fram is PH2 if you actually want to use them however.
Hope this helps.
Old 01-18-2011, 02:10 AM
terracedean
ok ya ill run to dodge and pick one up. Thanks alot!
Old 01-18-2011, 04:53 AM
bgbluram2's Avatar
bgbluram2
bgbluram2 is offline
MOPAR = MO899
K&N = HP-2010
MOBIL 1 = M1210
AC = PF1250
BALDWIN = B329
PUROLATOR = L24651
BOSCH = 3410
HASTINGS = LF110
Hope this helps.
So can we say without doubt that you dislike fram filters?
Old 01-18-2011, 11:13 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Ive used Fram on various rides over the years and never any issues. I will buy whatever is on sale at the time (within reason) but my oil never changes.
Old 01-18-2011, 06:10 PM
terracedean
What oil do you run? i just picked up that new castrol edge. well new to canada anyway haha
Old 01-19-2011, 02:07 AM
me0418840987's Avatar
me0418840987
me0418840987 is offline
Used to run Fram orange filters on all the Dodges. Switched to Pure Ones on the 05 after it was about 30,000 miles old, now 165,000mi and the 03 Neon when I got it at 189,000, now 229,000, and the oil was noticably cleaner in both at oil change time. Always used the same oil though, Shell rotella-T 5-40 synthetic in the pickup, and Valvoilne full synthetic in the neon. Still run a Fram on the 84 Dodge dump-225,000 mi and the 99 chevy 1 ton van 249,000mi, and they haven't had any lubrication problems.
Old 01-19-2011, 09:54 AM
Matt99's Avatar
Matt99
Matt99 is offline
Theyve done filtration tests on the filters and on each one, the frams are in the dirt. A step below EVERYTHING else. I usually buy WIX, as they are cheap but always score great on tests. I do it at 5k so paying $2 more for a filter doesnt kill me.
Im sure theres never been a catastrophic failure from a fram filter letting something by, but I can see an engine failing early from a low grade filter. In early, I mean 200k+ lol. My dad and grandpa only use Fram filters and have trucks with 240k and 330k, respectively.
Old 01-19-2011, 10:13 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
I learned a long time ago only to believe what I could prove to myself or make happen with my hands. I quit believing a lot of things on the internet a long time ago.
Old 01-19-2011, 10:01 PM
03celicagts's Avatar
03celicagts
03celicagts is offline
Ask no questions hear no lies
Quick Reply: Oil filter size?
