Where is the fuse for the reverse lights located?
Old 01-16-2011, 02:31 PM
MaximRecoil's Avatar
MaximRecoil
MaximRecoil is offline
Default Where is the fuse for the reverse lights located?
My reverse lights don't work, so I guess it could be the lamps, the reverse light switch, or the fuse. I want to check the fuse first.
Old 01-16-2011, 04:44 PM
bpark8824's Avatar
bpark8824
bpark8824 is offline
I'm not sure where it is. I have the same problem. Mine havn't worked in about a year. But I looked and since none of the fuses were blown, I didn't think it was the problem. I may have overlooked something though.
Old 01-16-2011, 04:46 PM
bwdakrt's Avatar
bwdakrt
bwdakrt is offline
Fuse #26 in the fuse panel on the drivers side of the dash.
Old 01-16-2011, 08:17 PM
bpark8824's Avatar
bpark8824
I hope you had to go out and in look and didn't know that off the top of your head lol.
Old 01-16-2011, 08:45 PM
bwdakrt's Avatar
bwdakrt
bwdakrt is offline
Nope sorry. My fingers never left my hand.
The wiring specs in the FSM is wonderful.
Old 01-16-2011, 09:54 PM
MaximRecoil
Thanks. That fuse is fine (checked visually and with a meter), so I guess it is most likely that the backup light switch is bad (since both lamps are not working). Is it much of a job to replace one of those?
Old 01-17-2011, 09:29 AM
bpark8824's Avatar
bpark8824
I'm guessing its the same reason mine do not work. I'm also now assuming it has to do with both of our trucks being a manual.
Old 02-03-2011, 03:29 AM
MaximRecoil
The problem was the reverse light switch. These cost about $15 from an auto parts store (significantly cheaper from e.g., RockAuto.com), and installing a new one brought both reverse lights back to life. It seemed like an easy job (especially if the vehicle is on a lift), because it only took my mechanic about a minute to do it.
Quick Reply: Where is the fuse for the reverse lights located?
