power steering pump removal
Old 01-15-2011, 04:09 PM
dodgeman52's Avatar
dodgeman52
dodgeman52 is offline
Default power steering pump removal
my sister had a 200 dodge status 2.4 4 valve and the power steerin pump went out how do u removal it? any tips aalso would be great
Old 01-15-2011, 08:29 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
POWER STEERING PUMP (2.0L/2.4L ENGINE)
NOTE: This vehicle is equipped with more than one type of power steering pump. The type of power steering pump used depends on what type of power steering system the vehicle is equipped with. The standard steering system uses a constant flow rate power steering pump. The variable-assist power steering system uses a variable flow rate power steering pump. The external difference between the two power steering pumps is the type of fitting used on the power steering fluid pressure hose connection to the power steering pump. The constant flow rate power steering pump uses a standard tube nut fitting at the power steering pump. The variable flow rate power steering pump uses a banjo type fitting at the power steering pump. The removal and installation procedures for both power steering pumps though is the same.
WARNING: POWER STEERING FLUID, ENGINE COMPONENTS AND EXHAUST SYSTEM MAY BE EXTREMELY HOT IF ENGINE HAS BEEN RUNNING. DO NOT START ENGINE WITH ANY LOOSE OR DISCONNECTED HOSES, OR ALLOW HOSES TO TOUCH HOT EXHAUST MANIFOLD OR CATALYST.
REMOVAL
Remove battery cable from (-) negative post on battery and isolate cable.
Siphon as much power steering fluid as possible out of the remote power steering fluid reservoir.
Raise vehicle.
Remove right front tire and wheel.
Remove the accessory drive splash shield Accessory Drive Splash Shield
Remove power steering fluid pressure hose from pressure fitting on power steering pump Power Steering Pressure Hose Attachment To Pump W/O Variable-Assist Steering or Power Steering Pressure Hose Attachment To Pump With Variable-Assist Steering Let power steering fluid drain out of the power steering fluid supply hose, power steering pump and power steering fluid pressure hose. After power steering fluid has drained out of pump and hose, install a cap on the power steering pressure hose and a plug in the power steering pump pressure fitting.
Remove hose clamp, attaching power steering fluid supply hose to the power steering pump suction fitting Power Steering Pressure Hose Attachment To Pump W/O Variable-Assist Steering or Power Steering Pressure Hose Attachment To Pump With Variable-Assist Steering Then remove power steering fluid supply hose from fitting. Install a cap on suction fitting of power steering pump.
Remove the heat shield for the antilock brakes hydraulic control unit Power Steering Pressure Hose Attachment To Pump W/O Variable-Assist Steering or Power Steering Pressure Hose Attachment To Pump With Variable-Assist Steering
Remove bolt at adjustment slot, Power Steering Pump Front Bracket Attachment (Typical) which attaches power steering pump front mounting bracket to the cast aluminum accessory drive bracket on engine.
Remove bolt Power Steering Pump Attachment To Rear Mounting Bracket attaching back of power steering pump to the cast aluminum mounting bracket.
Remove retainer for wheel speed sensor cable grommet Wheel Speed Sensor Cable Grommet Retainer from right inner fender.
Remove speed sensor cable sealing grommet from inner fender Wheel Speed Sensor Cable Connection To Vehicle Wiring Harness Disconnect the wheel speed sensor cable from the vehicle wiring harness Wheel Speed Sensor Cable Connection To Vehicle Wiring Harness Push vehicle wiring harness back through hole in inner fender.
If vehicle is not equipped with antilock brakes, just a sealing plug will be installed in the wheel speed sensor cable routing hole Cable Routing Hole Sealing Plug Remove the sealing plug from the hole.
Remove bolt attaching top of power steering pump front bracket to the cast aluminum mounting bracket Power Steering Pump Mounting Bolt Access to the top bolt is through the wheel speed sensor cable routing hole Access To Top Mounting Bolt For Power Steering Pump To access the bolt use a long extension and a 15 mm flex socket.
Remove power steering pump drive belt Power Steering Pump Mounting Bolt from power steering pump pulley
NOTE: The power steering pump can not be removed from the vehicle without first removing the power steering pump mounting bracket Power Steering Pump Mounting Bracket from the engine.
Remove power steering pump and its front mounting bracket as an assembly from the engine mounted power steering pump mounting bracket. Place the power steering pump on top of the antilock brakes hydraulic control unit.
Remove the power steering pump mounting bracket Power Steering Pump Mounting Bracket from the rear of the engine.
Remove power steering pump and front mounting bracket as an assembly from the engine and vehicle. Pump and mounting bracket is removable by bringing it out through the area between frame, rear of engine, driveshaft and front suspension crossmember Power Steering Pump Removal
Transfer any required parts as necessary, if a new pump is being installed. Refer to the Disassembly And Assembly section of this service manual group for the proper procedures.
INSTALLATION
Install power steering pump and mounting bracket as an assembly back in vehicle, using reverse order of removal Power Steering Pump Removal
Install the power steering pump mounting bracket on the rear of the engine Power Steering Pump Mounting Bracket Tighten the mounting bracket attaching bolts to a torque of 54 N·m (40 ft. lbs.)
Install power steering pump and front bracket on the cast aluminum engine bracket Power Steering Pump Front Bracket Attachment (Typical) Loosely install the bolt at the adjusting slot Power Steering Pump Front Bracket Attachment (Typical)
Loosely install the bolt mounting the power steering pump to its rear mounting bracket Power Steering Pump Attachment To Rear Mounting Bracket
Loosely install bolt attaching top of power steering pump front bracket to the cast aluminum accessory drive bracket Power Steering Pump Mounting Bolt Access to install the bolt is through the wheel speed sensor cable routing hole Access To Top Mounting Bolt For Power Steering Pump
Using a lint free towel, wipe clean all open power steering hose ends, and power steering pump fittings.
If the vehicle is not equipped with variable-assist power steering, install a new O-ring on end of power steering pressure hose fitting. Lubricate all O-rings using fresh clean power steering fluid.
If vehicle is equipped with variable-assist power steering, install a copper washer on each side of the power steering pressure hose banjo fitting, then loosely install the flow bolt through the center Pressure Fitting And Washers
Install the power steering pressure hose on the power steering pump pressure fitting. Loosely install tube nut into pressure fitting on power steering pump. Pressure hose must be installed between the front bracket of the power steering pump and power steering pump pulley.
Install power steering pump drive belt on power steering pump pulley.
Install a 1/2 in. breaker bar in the square adjusting hole in the front power steering pump mounting bracket Power Steering Pump Front Mounting Bracket Adjusting Hole Then using breaker bar rotate power steering pump to obtain the correct drive belt tension. See Accessory Drive Belts in Group 7 Cooling System of this service manual for the correct drive belt tension specification. When correct drive belt tension is obtained first tighten the bottom 2 adjusting slot bolts at the power steering pump cast mounting bracket to a torque of 54 N·m (40 ft. lbs.) Then tighten the power steering pump mounting bracket top pivot bolt to a torque of 54 N·m (40 ft. lbs.) Access to tighten and torque the bolt is through the wheel speed sensor cable routing hole Access To Top Mounting Bolt For Power Steering Pump
Position power steering pressure hose, so hose is not contacting the power steering pump pulley or the drive belt.
If vehicle is equipped with a standard tube nut on the power steering fluid pressure hose tighten the tube nut to a torque of 31 N·m (275 in. lbs.)
If vehicle is equipped with a banjo fitting on the power steering fluid pressure hose tighten the banjo fitting bolt a torque of 47 N·m (35 ft. lbs.)
Install power steering fluid supply hose on power steering pump suction fitting Power Steering Pressure Hose Attachment To Pump W/O Variable-Assist Steering or Power Steering Pressure Hose Attachment To Pump With Variable-Assist Steering Install hose clamp on hose. Be sure hose clamp is installed on hose past upset bead on suction fitting.
Install heat shield on hydraulic control unit for the antilock brake system Power Steering Pressure Hose Attachment To Pump W/O Variable-Assist Steering or Power Steering Pressure Hose Attachment To Pump With Variable-Assist Steering
Route the wiring harness connector for the wheel speed sensor cable through hole in inner fender. Connect vehicle wiring harness to wheel speed sensor cable Wheel Speed Sensor Cable Connection To Vehicle Wiring Harness
On a vehicle equipped with antilock brakes, install wheel speed sensor cable sealing grommet in routing hole. Install retainer for wheel speed sensor cable grommet Wheel Speed Sensor Cable Grommet Retainer on right inner fender.
On a vehicle not equipped with antilock brakes, install sealing plug back in routing hole Cable Routing Hole Sealing Plug
Install accessory drive splash shield Accessory Drive Splash Shield
Install wheel and tire. Tighten the wheel lug nuts in proper sequence until all lug nuts are torqued to half specification. Then repeat tightening sequence to full specified torque of 129 N·m (95 ft. lbs.)
Lower vehicle
CAUTION: Do not use automatic transmission fluid in power steering system. Only use Mopar®, Power Steering Fluid, or equivalent.
Fill power steering reservoir to correct fluid level.
Connect negative cable back on negative post of battery.
Start the engine and let run for a few seconds. Then turn the engine off.
Add fluid if necessary. Repeat the above procedure until the fluid level remains constant after running the engine.
Raise front wheels of vehicle off the ground.
Start engine, then slowly turn steering wheel right and left several times until lightly contacting the wheel stops. Then turn the engine off.
Add power steering fluid if necessary.
Lower the vehicle. Start engine again and turn the steering wheel slowly from lock to lock.
Stop the engine. Check the fluid level and refill as required.
If the fluid is extremely foamy, allow the vehicle to stabilize a few minutes, then repeat the above procedure.
After power steering pump is installed, check for leaks at all hose connections and power steering pump fittings.
Quick Reply: power steering pump removal
