4x4 Light Wont Turn On
Old 01-12-2011, 03:54 PM
edlucky1's Avatar
edlucky1
edlucky1 is offline
Default 4x4 Light Wont Turn On
What would cause the 4x4 light to stay off when engaged in 4 wheel drive? It seems like the truck is in 4wd but the light never comes on, same for hi and low.
Old 01-12-2011, 04:22 PM
lukeca's Avatar
lukeca
lukeca is offline
I've seen a few others talking about this, if you are sure the 4x4 is properly engaging then either the light is burned out in the dash, or the switch on the cad that controls the dash light is failed
Old 01-12-2011, 04:57 PM
joshmopar's Avatar
joshmopar
joshmopar is offline
the light only comes on if the front axle engauges. If this does not happen the light will not come on. Check the vacuum hoses going to the cad. They run to the t case along the pass side frame rail.
Quick Reply: 4x4 Light Wont Turn On
